Installing Redarc brake controller ??
JPXR
Tim
Columbus Ohio
’22 JLUW XR 2.0T, ‘23 JLU 4xe Sahara
IT
I am installing the Redarc brake controller on a ‘23 sahara that did not come with the factory trailer wiring kit.
I have since installed the mopar trailer wiring kit to the jeep.
Will is the jeep have the harness under the dash for at least the power inputs and I just need to run the brake output wire? Or will I have to bring power, ground, brake power in and brake output wires to under the dash?
If I have to wire everything, does anyone know where to tap into?
Casper_
Casper
AZ
Jeep 392 2024
On the 2024 there is a harness under the driver side dashboard for the Mopar brake controller, high in the corner closest to the wheel. Using the Redarc harness: Gladiator/Wrangler suitable Tow-Pro Brake Controller Harness (TPH-022) makes it plug and play.
Lastly, you'll need to figure where to mount the rotary switch.
