Mopar or RedArc brake controller?
CRZYCDN
Matthew
St-Lazare
2024 JL XR Unlimited
Hi All,
I have a 2024 JLURX with tow package, so I'm looking at the 2 brake controllers... anyone know of any sales/special pricing with labor day?
As well any major pros or cons between the two?
Side note is there beefier trailer hitch for the JL? I belive it's a Class II from factory, I'd like to install a class III.
Thanks
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Hi All,
Thanks
It's a weird Class II rated with a 2" tube like a class III.
The big guys have brought out class IIIs in the last year, I think originally Draw Tite's Max Frame was the first one rated over stock.
All are crossmember mounted that I've seen.
driventoadventure
Lrr
Northern Front-Range, Colorado
21 JLURD
Employed Gainfully
Personally, I went REDARC because it's like half the cost, MUCH easier to install, doesn't remove the 12v outlet in the dash, and can easily be done to look very clean. There's a Tekonsha wiring harness (https://www.amazon.com/gp/product/B08288R363/ref=ppx_yo_dt_b_asin_title_o00_s02?ie=UTF8&psc=1) that is a direct 1:1 install with the correct harness on both sides so that you don't even have to put the effort into the wiring harness.
As to the receiver, it actually IS a class 3 receiver, but the manuals etc call it a class 2 solely because of the towing limits. If you have the factory tow package, then the only thing you need to do anything to tow what the Jeep is actually capable of towing is install the brake controller.
Jeep Wrangler JL Mopar or RedArc brake controller? 1724857562760-x5
Aturking
Andrew
Avon,OH
2023 Wrangler Unlimited Willys
I have the mopar controller. I liked how it blended seamlessly and matched the radio buttons… it works good! You can get them on sale for around 300 bucks. I never used the 12v power. I had to modify the mounting location of the inertia unit since I have a manual, but was a plug and play install.
The redarc units are super nice and were a close 2nd for me. I just wanted to be bougie with the matching knob
CRZYCDN
CRZYCDN
Matthew
St-Lazare
I've looked a couple spots and the mopar one seems to be sold out? In comparison the Mopar seems to be $100 more (Canadian loonies)
I can't find any cons between the two, so I may venture down the RedArc path and be able to stick the small knob and maintain the 12v plug.
CRZYCDN
CRZYCDN
Matthew
St-Lazare
The other kicker seems the redesign of the '24 dash...its way more invasive to get at the 12v plug in the lower dash. So the smaller RedArc may be the best fit for the job and I can install it in an accessible spot.
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
Anybody consider a Curt Echo?
GATORB8
CLT NC
I've got an Echo but haven't needed to use it, just sits in the truck as for just in case. Only real downside is loosing the hard trailer brake button.
I run a AuTowBrake on the off road trailer and that works fine. Most of my tow braking issues with the Jeep stem from it being a 4xe.
BobW
Bob
Ventura County
Thanks!
The Mopar OEM controller is evidently not compatible (?!*) with with 2018/2019 JL (I retrofit the Mopar harness myself) . Under what conditions do you use the manual brake?
GATORB8
CLT NC
Thanks!
Probably the most important use of a manual brake is snapping a trailer out of a tail wag. I've never had to use it for that, but it's also a good way to test set the strength level/gain of the controller.
Aturking
Andrew
Avon,OH
Lots of people love the red arc, can’t go wrong with either
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
I also have Redarc and it works great. That small knob can be mounted almost anywhere. They also have a plug and play harness for the tow package Jeeps but it's not hard if you don't have it. I looked at the Curt Echo but being exposed makes it easy to damage and easy to steal.
GATORB8
CLT NC
I also have Redarc and it works great. That small knob can be mounted almost anywhere. They also have a plug and play harness for the tow package Jeeps but it's not hard if you don't have it. I looked at the Curt Echo but bring exposed makes it easy to damage and easy to steal.
Curt did bring out two other versions of the Echo, neither are cheap. There is an under dash and a behind the hitch version.
driventoadventure
Lrr
21 JLURD
Employed Gainfully
I've heard nothing but bad about them, and they rely on your phone for any manual action. Not smart for an emergency.
driventoadventure
Lrr
21 JLURD
Employed Gainfully
Thanks!
The manual breaking is good if you blow a tire on either the TV or trailer. Also good for arresting sway even with a sway controlling hitch. Also good for wet conditions if you have traction issues in the front of your TV. Also good backup for downhill towing, more control if you can easily increase breaking when needed or turn it off when your trailer brakes are overheating and you are engine breaking.
