roaniecowpony
You really care about the other way around, a lot more. If there's coolant in the oil, it's not going to keep getting more and more, unless coolant is leaking into the oil system somewhere. So, drain and send a sample to your favorite oil lab, then change the oil a few times in very short intervals (using an inexpensive oil like Walmart Super Tech or Kirkland), then send another sample. It should get less and less coolant in the oil. If not, you have a wounded engine. This is the process I used.So this is a very long update. Of course my Jeep overheated again after I put about 50 miles on it. I called Jeep customer cares again and they advised me to take it to a different dealership. I towed my Jeep up there on a Sunday and on Monday around noon they contacted me to tell me I had a cracked oil cooler. It took about a month of back and forth with Jeep and the dealership (some of that was because of the dealership software getting ransom wared), but Jeep came through and I only ended up paying 100 dollars to get the oil cooler, thermostat, hoses, and coolant bottle replaced. I picked up the Jeep a couple days ago and there's still a bit of oil in the coolant. I let the dealership know and they stated that they could flush it 50 times and there would still be some oil. I've read that flushing with dishwasher detergent could solve this issue. Does anyone have thoughts on that?
