Hitch cargo carriers
Afishinado
Black Hills SD
21 Sahara, 17 JKU Big Bear, 97 TJ
UGH! I can't begin to tell you how much I hate having something like one of these on my vehicle... So on a whim, I added this JL to my garage and replaced a Tahoe, it is nice, I did it because 359 days a year a vehicle the size of the Tahoe is simply not necessary, and it's just a big foot print in the garage. I figured I could live with being a little crowded 6 days a year.... Well we took a one day trip with our 3 dogs, and we were pretty crowded. End of November we'll be doing three 12 hour days running from SD to FL. Always figured if it don't work, I'd just trade it for a Tahoe or a Wagoneer. So that's not happening by Thanksgiving (but hopefully by May when we do the same trip in reverse...
So, forgive my verbose unnecessary background above. I think I can get by with a Hitch Cargo Carrier like the one linked. So my question to those that have one; Does it fit behind the spare? If I put one of those extensions on it, will it rattle around for the 2300 mile trip?
Hopefully I will have a Wagoneer or Tahoe by May...
GeckoJosh
Josh
Pennsylvania
2015 JKU Baja Yellow
I used one on multiple trips from PA to Georgia, PA to Vermont and PA to Maine. Got mine at Harbor Freight and also ordered a water proof bag to stuff our crud in there. Of course mine is on my JKU, JLU not here yet but not sure if there is a difference in the rear.
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
Afishinado
Afishinado
Black Hills SD
Do you have the steel one or the aluminum one? The aluminum one I think is a lot taller and might need to be removed to open the door. You will find there is a difference in the bumper on the JL from your JKU. The space (or indentation) for the spare is flat on the bottom, where your JK is round matching the tire. I've had the HF steel one, I think it would work, but I think the aluminum would be nice when I need to move it around for storage. BTW, the most I see ever on it is maybe 60lbs.
Afishinado
Afishinado
Black Hills SD
Thanks guys! I just ordered this one. I'm set. Thanks again for the input.
Jeep Wrangler JL Hitch cargo carriers 81DZG39t3VL._AC_SL1500_
LittleDog
New Jersey
2020 Sahara JLU
Guess nobody's stealing those gas cans.
@Afishinado I'd definitely go for aluminum for light weight and rust inhibition. I've an aluminum Curt tray that weighs around 20 lbs, and it is amazing being able to easily pick it up and swing it around or overhead.
The centre post is usually still steel, but I recommend replacing nuts and bolts with stainless when you first assemble.
Hitch tighteners will fix the rattle and wobble. Get two if you use an extension.
You said you only have 60lbs of cargo or so, but just remember that a hitch extension will typically halve the load capacity. And be prepared to scare yourself when you drag the tray on steep off-exit gas staion entrances.
Afishinado
Afishinado
Black Hills SD
The one I ordered is aluminum, 21.6lbs... I never saw the tighteners until today while shopping for the rack. Will get a set. Thanks
au1994
Cumming, GA
Sahara 4xe, BMW X1
Chickens
Yeah, I was going to ask about this. I could use one but concerned about what it does to the approach and departure angle. My driveway is s little steep.
LittleDog
New Jersey
2020 Sahara JLU
Tough to say, without me getting a protractor, then you getting a protractor, then both of us looking up how to use them correctly.
I use mine on a swing-away hitch, which extends the tray, but also raises it the one hitch height:
Jeep Wrangler JL Hitch cargo carriers 20210909_182139
It weighs more than the tray though.
I'd say your best bet would be to get a yardstick and tape it to the bottom of your hitch, out to the width of the tray you are planning to buy. Remember to add the length of the original tray extension and any extender you may add.
Then go down the driveway and see if it scrapes. Remember to account for the sideways length at the ends of the tray, for when you turn out of the driveway.
Good luck.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
I have the cargo carrier with the weather resistant bag. We encountered a lot of rain but everything stayed dry. It does a good job. It does clear the spare, but I can not open the tailgate with all my stuff on the carrier. I used those nylon wedges to keep the carrier from rocking.
Zoopy123
Trevor
MA
4xe Sahara
Media Services
How'd that Harbor Freight cargo hitch work out? Was looking at the same one but wondered if it would clear the rear spare tire
Vanburi
North Texas
2019 'Mojito' JLR
For my harbor freight hitch carrier(the aluminum model), I use a hitch extender to clear the spare.
