High Oil temperature
RubyRecon
The OC
2020 Rubicon Recon
My 392 oil temperature runs around 235 degrees just running around town. Does that seem high ? Water temp is usually in the low 200s.
Pape
Quebec
JLU Sahara
Other will chime in for sure.
For me start and stop always make the oil more hot that an steady drive.
Never reached that temperature but I'm not in the same context as you.
In any case max I have see is around 220F
stumblinhorse
235 is a little lower than you want. Oil needs to get moisture out and a good 250° for a little bit will get it out. Oil starts to break down over 300°. So you have lots of room. Especially 0w40…
Fast-n-Furious
PA
2022 392 XR
Normal. Mine is ranging between 220 and 240 constantly daily driving, summer or winter. It goes a bit higher in off-road + mode.
Rick4570
Virginia
2022 Jeep Wrangler
Thats ridiculous. You don't need 250 degrees to get the moisture out. A long highway drive at 199 will do it just fine.
Rick4570
Virginia
2022 Jeep Wrangler
I wonder how the water boils out at lower than its boiling point…. But that is just science, in today’s society science takes a backseat.
Put a pot on the stove and heat it up to 190 degrees. Now place a couple of drops of water in it. Or even a couple spoonfuls. Come back in a bit and see the water gone. Water does not need to reach boiling point to evaporate. A good long highway trip at 190 degrees will keep the moisture down in the oil.
stumblinhorse
Put a pan on the stove with motor oil in it. Put water in the motor oil and heat to 190, the water will never come out off the oil.
But all this is moot since the 392 almost always get above 220 when doing anything. Mine runs 240-250 on every drive even at -30°f…
Rick4570
Virginia
2022 Jeep Wrangler
If that is the case, then I am wrong. I have read otherwise, but who knows if what I read was correct? In any event, thanks for the info! Have a great day!
SSWIM
Sam
Too Many
Completely normal. Don't worry about it. Drive it. Enjoy it.
Sam
RubyRecon
RubyRecon
The OC
2020 Rubicon Recon
Thank you everyone. My 2020 with a 2.0 turbo very seldom gets over 220degrees.
As far as having to be above 212 degrees to remove moisture, I am pretty sure when the oil is squeezed between the cylinder walls and pistons, etc, it spikes and then cools while returning to the oil pan.
