Help with rockjock antirock
Djhyper66
JOHN
Corona Ca.
Jeep Wrangler 2020 JL
When installing the arm .. I can’t get it get it installed level… does the bar need to be installed level as possible ?? Seem mine at a huge angle … any advice or tips … do I need to have this install on a huge lift???
Jeep Wrangler JL Help with rockjock antirock 3804653C-94C5-4F3A-9049-1C449340B7B1
rkwfxd
Rich
Whittier
Unemployed
It’s better to have the end links too long than too short.
zouch
Berkeley, CA
XJ, JLUWD
have you got the minimum lift Rock Jock recommends?
the adjustable links come in different lengths, too; you could contact them to see what they says about you maybe needing a different length link.
ssrgeoff
PNW
2021 JTR, 2022 JLURD
Mine sat right around there maybe a little less of an angle. You can order shorter end links but I wouldn't say to go level as you don't want it to flip around in full droop. I came across a video awhile back that showed how to measure your down and up travel to find the sweet spot.
Djhyper66
Djhyper66
JOHN
Corona Ca.
I have a mopar lift … just all the video I see online the bar wasn’t as slanted .. but I guess it depends on the length of the end links and lift ..
firedude
Bret
AZ
2022 Rubicon XR 392 Stingray
Retired firefighter
The antirock arms should only be level at mid shock travel. Jeep needs to be in the middle of total shock travel then arms can be leveled. I had to trim a couple of mine. You also need to full droop it to make sure there is no chance of it flipping or reversing as mentioned above.
