Help with rear diff identification/ what oil do i need
Lenny7888
Josh
Uk
Jl
Hi guys I need some help with what diff this is on my Jl wrangler 2021. I have a leaky end seal I believe and am waiting for it to be looked at warranty wise. Can anyone help with what diff it is and what oil I can top it up with / change it . Thank you
https://ibb.co/T2RFc1j
https://ibb.co/V3DrDzK
zouch
Berkeley, CA
XJ, JLUWD
what does your Owners Manual say?
if it’s just going to be leaking out anyway, anything that meets the spec in the manual and you can find at your FLAPS is better than letting it run low.
the only caveat would be if someone had put a gear-driven Limited Slip Dif in there; in that case you’d use what the LSD mfr wanted (likely a non-synthetic). but i’ll bet that doesn’t apply in your case.
Old Dogger
Cave Creek Arizona
Your Wranglers Owner manual, is your best friend for maintenance advice.
Lenny7888
Josh
Uk
Jl
Not enough pictured in your photos for me to ID the diff, but this might help.
Thanks I'm sure it's the m220 and this is the spec off my vin build sheet.
4:1 ROCK-TRAC HD FULL TIME 4WD SYS
DANA M210 FRONT AXLE
4.10 REAR AXLE RATIO
DANA M220 REAR AXLE
TRU-LOK FRONT & REAR AXLES
ParadigmDawg
Greg
Fort Worth TX
Go get some Mobil 1 or Lucas synthetic diff oil and some RTV. Pull the cover, clean the surfaces and slap it back together. It takes 20 minutes.
Barney392
Lake Havasu, AZ
No RTV is required. The gaskets are reusable. Check your owners manual for the lube weight. Probably 75W85 but check to make sure.
ParadigmDawg
Greg
Fort Worth TX
That's true, my gasket was ripped from too many diff hits when I changed mine. I have no idea why I didn't dump out all my fluid but it was still holding.
