help I'm going crazy
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
I fix that, but now the car shows dtc B16D7-15, the car runs but slowly over 2K rpm.
Any idea what could it be
B16D7-15 is: Left Taillamp 1 Control - Circuit Short To Battery Or Open
You may want to fix this circuit issue.
Causes could be:
  • Faulty Left Rear Park Lamp
  • Left Rear Park Lamp harness is open or shorted
  • Left Rear Park Lamp circuit poor electrical connection
  • Faulty Body Control Module (BCM)
AC1982
AC1982
Alonso
Costa Rica
Wrangler Rubicon Unlimited JL
Causes could be:
weird because the lights are working correctly
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Did you pull the fuse box to service the auxiliary battery?
MtCamper
Ken
NW Montana and Yuma Az
2018 JlUR White Rubi, 2022 Chevy 3500, 2016 27-5L
Retired, Snowbird
I think I would pull the fuse box again, spray it down with electric contact cleaner and reinstall it.
AC1982
AC1982
Alonso
Costa Rica
you think the problem comes from the fuse box ?
Im thinking of buyin a new one, Im tired of dealing with this
mwilk012
Service
Im thinking in buy a new one, Im tired of dealing with this
you likely damaged a pin, no amount of spraying will fix that.
speedymart
mephis
2021 jl
That U code is NOT the cause of your CEL. Pull all the codes and tell us. It sounds like you used the tazer to see the codes, saw one, and thought that was it before you finished scrolling through everything. Use a normal scanner.
Your vehicle is going into limp mode after driving, there will be P codes present. It is not the battery, alternator, fuse box, or anything else that was mentioned in this thread. It IS possible you blew something when you removed the fuse box, causing even more issues. I suspect you blew your z-case fuse array or didn't tighten one of the 3 bots in the PDC correctly.
AC1982
AC1982
Alonso
Costa Rica
ok, I got the B210a-00 (low voltage) I replaced the battery but the tazer shows B16D7 -15 and the car runs without force over 3k rpm. We used a scanner and only shows the B16D7 -15 and P1D3000 (oil viscosity) that is there long time ago (the car refuses to reset oil life, tried different ways to reset without success, everytime I start the car shows me the alert that need to change oil but never a check engine light, thats why I take a picture to the millage and chance oil every 3K miles)
I clear the The code B16D7 -15 but check engine light is still there but the code dissapears of the scanner, after a while it the code appears in scanner again
speedymart
mephis
2021 jl
P1D3000 is not a real DTC. Get a different scanner and give that a try. I suspect your scanner isn't picking up all the codes properly. I don't think 3.6L even have an oil viscosity DTC, that's a hemi thing.
AC1982
AC1982
Alonso
Costa Rica
test with another scanner and this time shows P2390 and P227F
