Has anyone hit their transmission hard while wheeling?
DiamondJeep
JLU
I know the manual transmission JL's are missing the extra crossmember in front of the transfer case that the automatic JL's have fresh off the lot so I was wondering if anyone has wheeled their Jeeps stock without skid plates and actually hit their transmission, transfer case, oil pan, or etc. while out on the trails. Pretty much trying to figure out if the transmission, transfer case, oil pan, or etc can survive a really hard hit from rocks. So if you've been wheeling out on the trails without skid plates and actually hit your transmission, transfer case, oil pan, or etc really hard on rocks or whatever let me know what happened next if it was ok with no issues or was there issues after that? Thanks!
word302
Oregon
JLU
It’s not gonna end well, get skid plates.
blnewt
New Mexico
Just ask @cosine he knows!
Really hard hit on a really hard rock, survive maybe, but not worth the risk IMO. You wouldn't want to chip that Diamond :)
And FWIW, the stock skid plates/bars on even the AT equipped JLs are minimal, better than nothing, but there's plenty of places that damage can occur on the rocks.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
My first mods on a new Jeep are skid plates. No reason to risk trail damage.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
We have the 8AT, so we have the trans skid plate/bar.
Depends on your definition of "hard", I've dropped it hard enough to bend the skid bar up 1" directly below the front driveshaft.
OBJLU
Henry
Los Angeles
2018 JLU Rubicon
Get the Off-road Evolution engine and transmission skid plate. You don’t want to chance it.
Krondor
Here, but soon there
2018 Punk'n Jeep Wrangler JLR
Took my Jeep out when it had temp tags and had a lot of fun.
No skids, but I was careful on where I went and what line I took. Bouncing can put your belly in danger, so if that's your style or fear then get some good skid plates.
I was worried about the extra weight, but didn't notice it nearly as much as the heavier tires. I will say that having skids makes you take a few more risks, so use with care. ?
Traveller128
Robert
Oasis Idaho
2022 Willys 2 Door 6 speed
Volvo Master Technician
Our 2022 manual trans Willys had the crossbar forward of the transfer case skid. The build sheet shows "transmission skid plate" but it's a single bar, with a leg that attaches back to the transfer skid held on by the two bolts to the frame and one on the rear leg at the transfer case skid front bar. We removed it and put in an aluminum M.O.R.E. engine/trans skid. MUCH better protected now.
But I did want to point out that our manual trans 2 door had the "skid" bar where some of the manual trans vehicles I've seen didn't. Looks the same as the auto trans bar.
That being said, I think the manual is tucked up there well enough that you'd have to do something pretty severe to hit it, it would have to get up into the chassis, something like a tall, pointed rock or something to reach that far up, and you'd have to come down onto it.
AnnDee4444
'18 JLR 2.0
The 2-door's gas tank has a bolt that goes through the front "skid" (at least it did in 2018... not sure about 2019+ 2-doors with the smaller tank).
