Anyone planning on regear their 392?
Laserflorida
2019 moab
392 coming with 3.73. Planning on 37’s. I put 4.56 on my 2019 Moab with 37’s with a very noticeable improvement in ride quality. Anyone planning on regearing their 392 with larger tires?
Laserflorida
2019 moab
any recommendations?
i spoke to someone at 4 wheel parts today and they had no idea that the 392 was a production item and no idea of the gearing.
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
I’d drive it first and go from there. With the power it puts out, it might be able to compensate fine and drive terrific
brett
AnnDee4444
'18 JLR 2.0
Yeah but torque multiplication will be “slightly” better😜
Actually it's slightly less than the theoretical maximum of a 2.0 Rubicon in 4-low.
2.0: 295 lb.-ft. x 4.71: first gear x 4:1 transfer case x 4.10:1 differential ratio = 22,787 lb.-ft. @ axle
392
: 470 lb.-ft. x 4.71: first gear x 2.72:1 transfer case x 3.73:1 differential ratio = 22,459 lb.-ft. @ axle
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
392
So you saying the 392 needs more torque right? SUPERCHARGER!!!!!
AnnDee4444
'18 JLR 2.0
Probably not, I've never felt the 2.0 was lacking in torque off-road Yes of course it needs more torque. The Hellcat supercharger should be a dealer installed Mopar option.
word302
Oregon
JLU
392
Sure at WOT, but anyone wheeling the 392 like that is gonna grenade parts pretty damn quick. The low end torque of the 392 will perform exponentially better in real-world wheeling.
AnnDee4444
'18 JLR 2.0
FWIW: I've read that the 2.0 limits torque in 4-low. I suspect this is probably true for all engines.
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
I've never felt the need for more torque. I've never not had enough torque available to do whatever stupidity I was trying to accomplish.
But your point is probably very true - the 392 should be much more progressive in how the torque comes in. This could be really helpful in certain situations where you want to tip in gently. That will probably keep the axles in one piece a bit longer too ;)
