MINNESOTA 68
MN
2024 Jeep Rubicon
After looking for a decent hitch rack I decided to try this one from Harbor freight:
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008178
The walls were to tall for it to work on my 2024 rubicon so I decided to chop it. After it was assembled I measured down 3 inches from top all the way around
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008148
Chopped it with an angle grinder then drilled new holes and bolted the bottom back on
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008166
This got me to about 4 inches of height and it now works perfect
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008176
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008177
This took about 2 hours all together but that included time to figure it out. All together for under 100 dollars I am very happy with this rack.
YGBSM392
Oklahoma City
2025 Rubicon 392, 2024 2-Door Rubicon X, 2024 Mojave X
I fly da plane...
Great fix. Thanks for posting!
Porthole
Duane
LSD Delaware
2019 Jeep Wrangler JL Sport S
Retired, Career FIre
Since you've already played around with this, is the rack made that it could be shortened?
I'm thinking about this to use on an existing swing-away carrier but want something a bit smaller, just a cooler mostly.
My local HF only has the hang tags on display, no product.
somdfisher
Kenny
Southern Maryland
2021 Jeep JLU 80th Anniversary
Construction Manager
I bought the same rack and put it together this past weekend. It seems nice for its price point, and doesn't rattle around much when in the receiver. I don't have a spare tire carrier on my Jeep. I only test fitted and didn't put the pin in, nor did I test the gate, but it looks like I won't have to modify it.
MINNESOTA 68
MINNESOTA 68
MN
2024 Jeep Rubicon
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008180
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008188
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008189
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008184
Jeep Wrangler JL Harbor freight hitch rack modifications DIY 1000008182
The bottom part of this comes mostly assembled, and it is welded together. However I think you could probably shorten it some and then re assemble the rim that the top section attaches too. If I wanted it smaller I would feel 70% confident I could make it to be an overall smaller footprint and still look decent. Of course before I started with the side I had figured thst if it went bad, I would still be able to salvage it for something and worse case I am out 100 dollars and got to have some fun.
MINNESOTA 68
MINNESOTA 68
MN
2024 Jeep Rubicon
Yes it was the spare tire that hit the rack and not by a whole lot, but I wanted to be able to open the back gate with it attached.
MINNESOTA 68
MINNESOTA 68
MN
2024 Jeep Rubicon
having the same. Only use the bottom part.
That was mt backup plan if I messed it up too bad haha.
Have you had it for a while, how do you like it?
TBULL52
Jack
Crofton, MD
@MINNESOTA 68 are you looking to keep it on all the time? I love what you did and that you could do it but am having a hard time understanding why. As soon as you put anything on it you're not going to be able to open the door again. I have a rack that I use, when I get to where I'm going (typically camping when I use it), I unload the the rack and then remove it until I am packing back up.
MINNESOTA 68
MINNESOTA 68
MN
2024 Jeep Rubicon
Just like the flexibility, will take it off when we are staying in hotel. If at cabin for weekend might leave it on and just take cooler off. I can still get into the back pretty easy with this attached and feel it will be nice if there is 1 more thing to add if I can just pull off cooler and not whole rack.
C.Sco
2023 4xe Rubicon
This is awesome, I think I'm going to do exactly this, thank you for the writeup and pictures!
