Grill Gaurd Causing Overheat?
HeavyMetalFox
Chic-ette
Fruitvale BC Canada
2020 JLUR Recon Edition
RMT
So I have a Dirty Acres grill gaurd. I’ve had it two years now. My first summer with it I was overlanding and travelling up a very steep mountain pass with a fully loaded down Jeep and my radiator blew up! I off road it lots and have Overlanded it in the mountains while loaded down without an issue. But last summer I was travelling through the desert when it happened. At the time I got lots of feed back saying the new roads with the plastic components are notorious for overheating. It was replaced but now when I push it hard off roading even in the winter, or idle for a while outside my kids dance class I can start to smell rad fluid. I’m starting to suspect it could be because of the grill guard. I’ll try to post a pic of it. Anyone else had issues with their newer rad with plastic components over heating? Is it just typical and I need to upgrade to aluminum? Or did you also put in A grill guard and had similar issues?
Jeep Wrangler JL Grill Gaurd Causing Overheat? 44C769F9-7970-42C8-8C0C-9FAE3DC4E843
lowmpg
Ryan
Kent Island, Maryland
2021 Rubicon, 2025 Ram Limited
Didn't say which motor you have but 3.6's run hot as it is, fan is constantly on, so putting anything in front of the grill seem inherently bad.
Georgia
2019 jlr
My friend had a grate just like that which constantly caused overheating on the trails. Not so bad on the road. So I guess I can vicariously confirm that it is at least part of the problem.
Best of luck keeping cool out there!
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Why don't you take it off for a few days and see what happens?
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
[/I have a USMap so far not a problem but summer hasn’t started yetQUOTE]
MauiSteve
Stephen Rodgers
2021 Rubicon 2 door, 2018 Colorado ZR2, 2009 Honda Ruckus, 1973 Honda CB750
Mostly retired
at one point in my past I did some ventilation testing and balancing with some cool instruments.
that grill is restricting air flow……….a lot!!
mwilk012
2018 Ocean Blue JLU Rubicon
Service
What do you mean by “newer” radiators with plastic components? Has it been 40 years since you bought a car?
when you say it is overheating, what do you mean?
Maverick909
I.E.
The easiest thing to to remove and go for a drive. You are restricting 40+% airflow with that setup. Just think the JK’s didn’t have grill Guards at all
Kracka
Christopher
Oak Point, TX
C8 Corvette, 19 KL Trailhawk Elite, 23 JL Rubicon
More like 80%+ restriction. Let your poor Jeep breath!
Muddiver
Everett
2023 JL 4Xe
One other option is to add hood vents and possibly side fender vents. But I agree that putting a sheet like that across the grill area is blocking the required air flow through the radiator.
