GOOD OPTIONS TO TIGHTEN STEERING?
Rubywood
Ken
Burnside KY
2022 Wrangler Unlimited Rubicon
OK, sorry for an old topic revisited, but I just purchased my first Jeep, '22 Wrangler Unlimited Rubicon, 35's with factory 1,5" lift. I wasn't surprised by the somewhat loose feeling of my steering after researching threads here in the forum. My Rubicon will be an every day vehicle for me, maybe 20k miles a year, and sometimes pulled behind our camper. I would like to have a tighter feeling to the steering and there appears to be a lot of options and prices out there. Knowing how I paln to use my Jeep, looking for thoughts from those more educated on this subject than me. Thanks in advance for your input.
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
I had a huge improvement of steering feel with an upgraded tie rod, drag link, ball joints and sector shaft brace.
I'd start with ball joints since you have 35" tires. Even stock 33's are a lot for the factory ball joints.
Also watch this:
Rubywood
Ken
Burnside KY
Also watch this:
Thanks Cips......great video for front end inspection
Richard_JL
Larry
Boca Raton, FL
2026 JLU Rubicon 3.6L
IT Director
A Wrangler will never drive tighter and straighter than when brand new, so the above is good advice; replace what wears out over time. The heavier the corners (big wheels/tires/brakes), and any use of spacers will wear things out sooner than stock.
vetygud
Michael
Nisswa, MN
2022 Jeep Willys 2 door Sarge
Retired LEO
A new upgraded steering stabilizer can tighten up your steering. Make sure it isn't covering up any other worn out components.
Roky
Roky
Gonna disagree with this….every rig I’ve worked on since the JL came out, the customer always said “it drives better than stock”…. Not once in 8 years did anyone say “this drives like crap , put it back to stock” …in fact I’ve read this phrase a gazillion times on here alone…🤣
I could barely keep mine on the road bringing it home, (wandering), it got put on jack stands within a couple of days…🤣….. The new rigs might be better, I haven’t driven any of the new ones..(‘24 or newer)…….
Of course, the trick is to set it up right, paying attention to the geometry…Can’t just throw some spacers under it and not address other things and expect miracles…🤣
WXman
Central Kentucky
I had an early 2018 JLU (the first one in my area), a 2020 JT, a 2021 JT, and now a 2025 JLU. ALL of them handle(d) like a bass boat on the lake during a wind storm. Constant input needed with the steering wheel just to maintain a straight line. The electro-hydraulic steering system on these is just garbage. Get used to it, or buy a Bronco.
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
Obviously, there are numerous existing threads of this subject. I'm sure other individuals have had various degrees of success with post-factory-installed improvements for the sloppy steering.
Note - I'm running a takeoff Rubicon suspension with leveling spacers on my JLU so 2" over stock.
My recipe for improved steering:
- mopar LCAs (1/4" longer)
- Fox stabilizer in stock location & Exact Center secondary
- Mopar steel steering box (since older JLU)
Very satisfied with the solid feel now even on uneven payment or with high winds.
Just sharing my personal experience.
zouch
Berkeley, CA
XJ, JLUWD
JL(U)s steer nicely if properly set up; not loose at all.
sadly, few are delivered in proper trim, and others are made worse by inappropriate/incomplete modifications. many people will try to pass off the failure to set up properly as "that's just how J**ps drive; they all do that", but they don't have to. it's not incurable.
first things to do with your new used J**p would be to make sure what's there is right.
which steering box does it have? there was a program to replace the troublesome aluminum box; that might apply to yours if it hasn't already been taken care of.
next, get underneath it while someone wiggles the steering wheel back and forth and check to make sure everything is working properly at all the steering gear joints. if there's any play at any of them, that's a problem that needs to be addressed. Track Bars, Drag Links and Tie Rods are frequent culprits here.
not sure how many miles are on the one you got, but know that the ball joints on these things suck. there are plastic bits in them that wear out, and it's not reliably diagnosed until they're removed; wheels may seem solid during all the normal wiggle tests, and the ball joints still come out in pieces when replaced. (i was shocked at how trashed mine were when i replaced them as a 'preventative' measure even though they has 'seemed' to be OK doing all the regular on-car tests.)
next, consider adjustable Lower Control Arms; the Mopar arms aren't likely long enough to get out to the approximately 6º of Caster that most people seem to find the most suitable.
last would be a Steering Stabilizer. once everything else is set up properly you absolutely don't need a steering stabilizer at all unless you want to 'tune' the resistance felt when turning the steering wheel. yes, a SS might mask some other problems for at least a little while, but they're not the long-term solution.
WXman
Central Kentucky
Has anybody actually measured the pinion angle on a bone stock 2024-2026 Rubicon? Is it true that they come from the factory out of spec, or is that just hear-say?
nagoya10
Illinois
2023 High Tide
Buy a pair of 68322798AA Mopar Jeep extended lower front control arms and much of that wandering will disappear. I have the same Xtreme Recon package and I replaced my lower front control arms with these and had a great improvement and much better driving experience. These arms come in the Jeep Mopar accessory 2” lift kit so they are 100% Jeep factory parts. About $80 for the pair.
