Steering tightening
JINO
Jino
Socal
2021 jlurd
I got to my steering box, and can get the nut to move, but the inner hex will not budget from the nut. Anyone had this issue? Best way to go about this? A pipe is in the way, so I cant get good leverage. I torched it, but no luck.
Jeep Wrangler JL Steering tightening 20250630_185200
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
OMG! 😳 You have a giant snake in your engine!! It’s huge!!! No wonder you are having problems!
Looks like this one:
Jeep Wrangler JL Steering tightening IMG_3227
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
Have you considered replacing it with a steel/black steering box? This resolved my issues.
JINO
JINO
Jino
Socal
2021 jlurd
Holy shhht, just ran over my phone lol. Screen cracked a little, but nothing bad at all. Back got scratches since it was back down.
JINO
JINO
Jino
Socal
2021 jlurd
Is it still offered at jeep?
Htfan
Orange County, CA
2timing
N.E. Ohio
Jeeps
Get a good quality 3/8 drive 4mm or 5/32 socket hex key I believe 5/32 will need to be tapped in with a hammer . Put the socket on a long extension loosen the lock nut and you should have no problem getting it to turn.
JINO
JINO
Jino
Socal
2021 jlurd
Im not sure you saw the picture, but lot of stuff in the way.
Multiple things and hoses in the way. Would be an all day project! My disability prevents me from wrenching too hard (heart transplant).
2timing
N.E. Ohio
Jeeps
With the socket and extension I was able to move the hose slightly and get the Allen right in was less than 5 mins start to finish
JINO
JINO
Jino
Socal
2021 jlurd
When i watch the videos, I think my diesel is configured a little different than the gas models.
Ill give it another go sometime.
mgroeger
Southern UT
2021 JLUR 2.0T
Hopefully you know what you are doing by adjusting that because you can make it too tight and wear out the gear. I had the same problem, to loosen the alan head screw get the proper alan wrench and hit the tip with a torch. Get it nice and hot and then stick it in the alan head. Do this repeatedly about 3 times and tap it with a hammer. This will soften the locktite that is keeping you from turning it. It will still resist but will now turn. As others have noted I would def get the cast iron box.
JINO
JINO
Jino
Socal
2021 jlurd
Ill give it a try! I have 38s, so standing on a bucket is difficult to get any amount of torque haha!
mgroeger
Southern UT
2021 JLUR 2.0T
