GMRS antenna mounting
Tdkrum5
Ted
WA/AZ
20 White JLU Altitude
Tdkrum5
Ted
WA/AZ
MicroMobile MXTA25 3dB Gain Ghost Antenna
You can catch a glimpse of it here above the fender.
Thanks, I like this location, looks like it would also be good for a taller antenna. How well has it been working here? Do you think closer to the front would make any difference?
foxswimmer
Jason
Raleigh, NC
'20 JLUR, '04 Mazda3, '13 Sienna (because kids)
yes, it would work well with a taller antenna as well.
that location has been great for me. Reception has been fine for the groups I ride with. You can’t see it from the drivers seat and it hasn’t been an issue with snagging or catching on anything on the trail.
with the mount and rubicon fenders that is the only position that works. Without rubicon fenders there is one other mount point closer to the front.
Dalvarado55
Arizona
2018 Jeep JLU Sport 2.0, MC 3.5" lift, Rubi Axles
Here is my GMRS setup.
Happy New Year!
Larry
I have a similar set up that I just installed. I am curious, I checked my MXT275 with a SWR meter and my readings are at 2.8 on channel 1 and 2.5 on channel 22. I emailed Midland and they stated that the MXTA26 antenna would not have to be trimmed and that these readings are too high. They stated my antenna would not work in this setup. Did you use an SWR to check your readings?
Thanks,
prerunner1982
Jon
XJ Cherokees
Thanks,
Do you also have the spare tire in place? You might try taking it off and see if the SWR improves.
Dalvarado55
Arizona
I did take the readings with the spare tire mounted. I can try it later tonight with the spare off.
INCRHULK
Lance
Canada
litwphoto.com
2019 Wrangler Unlimited Sahara (retired), 2021 Gladiator Rubicon Diesel
Program Manager, Information Technology
Curious, does anyone have a CB and GMRS antenna mounted to the tailgate?
DrPerez007
Wisconsin
See Signature
Public Safety & Legal Consultant
Yes. I use two Kraken Offroad antenna mounts, one on each side of the spare tire mount. Link below. Pull the spare tire and they mount up in literally less than 2 minutes. Mounting the antennas and running the cables thru the tailgate door and into passenger compartment will take you a bit longer, obviously. I use only “no ground plane” antennas on these mounts; a 3’ Fiberglass Firestik for the CB on the passenger side and a Diamond Antenna NR73BNMO on the driver’s side for my VHF/UHF radio, which can run GMRS (& Ham). Then both seem to work fine although, keep in mind, every time you open the tailgate the coax will bend. Not a great long-term solution, but I live with it and it continues to work. No issues with the wiper. BTW, they like Mojito! LOL
https://krakenoffroad.com/product/jeep-antenna-and-flag-mount-bracket-for-wrangler-jl-jlu/
Not great photos but you get the idea.
Jeep Wrangler JL GMRS antenna mounting C952E76F-7F15-401E-B221-AD816E04FD7E
Jeep Wrangler JL GMRS antenna mounting DEC648F6-DAC6-4A6D-B5E6-E80DA0B7C77B
Jeep Wrangler JL GMRS antenna mounting F3F79E58-F63F-40F4-BED3-023739A9C9FC
Jeep Wrangler JL GMRS antenna mounting 7B01F747-23CF-4232-9CF3-28366DBB57BD
Pepe My Little Mule
J.D.
Pennsylvania
98 Jeep 4.7L; 2020 Jeep Wrangler Unlimited Willys
Thanks,
I run the same
Jeep Wrangler JL GMRS antenna mounting 20210130_151850
antenna there, never checked anything with a meter.... but it has always worked communicating with others who were miles away.
I too used the Kraken mount, but I also sanded the paint away the paint where the mount attaches to both the swing gate and where the antenna mounts to that mount itself....
DanW
My CB is mounted on the tailgate and works well.
unaseer
Umar
2018 Jeep Wrangler JL Rubicon
I mounted my ghost antenna on the hood. Haven't tested the signal strength yet.
Jeep Wrangler JL GMRS antenna mounting 20211117_150159
