front diff skid?
CloakedWillys
Summit Sponsor (Level 3)
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
Sales and tech support for MetalCloak
Not sure on zinc'd covers at this point. We did talk about the possibility of adding it as an option but not sure if or when.
CloakedWillys
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
It would seem to fit better with your other bits. Are they currently shipped raw or painted black?
They are currently shipped raw so that they can be coated however a customer wants. We have seen our other covers painted any number of ways.
Punk'n Head
chris
Culpeper va
2019 Jl Sport
any chance one will be made to work on the sport S front differential ? i have the Trailer package on mine which i believe you guys have a skid plate for the rear which i plan on getting and would like to have a front to match? thanks
TxJeepers
2025 JLUR '41
Any difference in fill capacity? Do you fill to the fill hole? Does it have the same channels for oil flow? Does it do a better job cooling?
No mention on the MC website concerning the fill hole being same as stock so you know when to stop filling. ie, fill until it starts coming out the hole. Not sure why they'd engineer this not to do that. All other top shelf diff covers do it.
Krondor
Here, but soon there
2018 Punk'n Jeep Wrangler JLR
I've gone through this before and overfilled my diffs because the aftermarket covers didn't account for fill levels. What a mess. :asshat:
lembowski
San Diego
2018 JLUR Sting Gray
Fill capacity should be same as stock. I will have to double check that the hole matches stock. No better job cooling but heat is not normally an issue for the front diff as it does not see big loads that generate heat like a diesel truck does towing.
@CloakedWillys can we get an update on the fill hole? Don't want to buy them off a "should be same as stock". If its not set as stock it would be a huge bummer....
CloakedWillys
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
Confirmed that the capacity is same as stock but the hole is higher. This means that it is not a fill till it flows out but make sure to measure out what goes in.
RubiJR
Inland Empire
2020 JLUR and 1992 Suzuki Sidekick
I've been waiting on the MC skid as well. I have the Rancho front skid and it took a hit this weekend. Protected the diff cover but the skid is apparently a one punch chump. It folded up into the cover so that I'm going to have to somehow bend it down to even access the lower cover bolts.
How hard did you hit the front diff skid from Rancho? I was looking into both and MetalCloak uses 7 gauge steel which is 13/16 and Rancho uses 1/4 High strength low alloy, which would translate to 4/16. The Rancho seems very slightly thicker so wouldn't that be slightly stronger? I know the engineering designs are different so would that strengthen the Metal Cloak? Thanks for your time
RubiJR
Inland Empire
It appears the way you hit your front diff skid may have had a worse effect without the extra front metal you taco'd. I'm curious why the full skids have the cool bolts and conical washers but the front diff skid bolts will get mangled and need to be replaced with that type of hit to the skid. In the end a diff skid is way better than no diff skid.
I'm still trying to find which is thicker and would that make it stronger - even if it does have the front glide
VA72mlibu
Eric
Alexandria, VA
2019 Mojito! JLR; 1972 Chevy Malibu; DHC-7 & BeechCraft King-Air (operated, not owned)
Anybody else have a slight rub on the Metalcloak front diff cover? Mine has a little paint spot rubbed off at the 1:30 position as you look at it.
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
Not noticed anything rubbing. Got a picture? Can you find traces of paint on anything that may rub it - track bar perhaps?
