Front Diff cover Fill Plug size
Ospreyfe55
Marc
Navarre, FL
2020 Jeep JLU Rubicon
So the last time time the dealer replaced the front axle seals they fubared my front fill plug. I’m going to have to drill or chisel it out! I am trying to find the thread size so I can get a replacement. Lots of websites have conflicting information as to what the proper plug is. Anyone know what size/thread type is or have an extra they want to let go of?
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
I will have a spare front and rear diff cover available once I change out mine to AEV. But thats not going to happen for next several weeks unfortunately due to work travel. I dont know if it will fit your '20 JLU, mine is '21 and does have a drain plug. But if you can/ will wait once I have a chance to change mine, I will have no use for the OEM covers
Terrymo
Terry
2023 JLURXR 3.6 ET
So, if the dealer messed it up, why not require the dealer to fix it? Just curious.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
This.
Also, which diff do you have. Some of us may have a spare they'd be willing to sell you cheap or even give you.
Ospreyfe55
Ospreyfe55
Marc
Navarre, FL
Well it’s been about 6 months since I had it at the dealer and now out of warranty. It would also be a finger pointing on who did what. Plus it’s a few weeks to even get it into the dealer. This mess up is the reason I do my own work, but since they covered the seal replacement it was easier to have them do it.
roaniecowpony
Retired Engineer
The threads in the cover will be fubar'd too. The right thing to do is to replace the cover and the plug. Simple job as I'm sure you know. The gasket is 100% reuseable as it is steel with a rubber molded seal. Do yourself a favor and just put a Motobilt or similar on it and be done.
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
The receipt will have the technician name on it
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I like this recommendation. Saves you the trouble of screwing with it. Just make sure whichever cover you get is compatible with your track bar.
GATORB8
CLT NC
I checked real quick, looks like the stock plug is only like $10:
https://parts.allmoparparts.com/oem-parts/mopar-differential-cover-plug-68401316ab
The full cover kit is $80ish. An aftermarket one will probably run $100-150.
You could try an easy out, but they probably impact gunned it on to mess it up in the first place, so that may end up being more than $80 worth of PITA.
$15 in gear oil if you swap the cover, or drill through the plug.
roaniecowpony
Retired Engineer
These should fit his JLUR
