Flat towing set up
richiee23
Richie
charleston wv
2024 jeep unlimited willys
The front end definitely came down. Between the dual battery and the bumper, I think it came down about an inch.
One of these days, I'm going to put a 2.5" lift on it. With us full time in our RV for the past 2 years, there's always something else to spend any extra $ on.:like:
Edit: I'm adding a picture of when we first picked up our RV. You can see the Jeep doesn't sit level and the front end is lower
I like how you installed the plug and brake breakaway behind the bumper. Looks clean
Edit: I'm adding a picture of when we first picked up our RV. You can see the Jeep doesn't sit level and the front end is lower.
you have a nice set up. If you have time could measure how high the mounting point on the bumper for the tow bar is from the ground. I have a class C and want to make it’s not gonna be to high once I install a 2.5 lift and 35’s.
azjl#3
North AZ
I was towing behind a class c, so hitch was very low, with my lift, i had to use the base plate option to keep it within the spec blue ox stated. 15k miles no issue. I did pretty much make the RVi brake controller emergency only, or manual on thier screen, I never needed it.
And avoid gw bridge in NYC, horrible oscillation due to crap upkeep.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Another vote for RockHard4x4 aluminum bumper. Paired with Blue Ox aluminum tow bar and a Demco Stay n Play braking system. All over the west and mountain passes. Quick to connect/disconnect.
Jeep Wrangler JL Flat towing set up IMG_4875
Jeep Wrangler JL Flat towing set up IMG_4473
Jeep Wrangler JL Flat towing set up IMG_2599
richiee23
Richie
charleston wv
Im worried a bumper will make the connection point to high. I could get a Gen Y hitch and use it as a raise hitch. I don’t wanna have to run like a 10 inch raise hitch, I would rather get road master direct connect baseplate.
RubiBlueJLU
Missouri
2021 JLUR Diesel
Structural Technician
I use a RockJock base plate on my 2021 JLURD. They have setups for plastic and steel factory bumpers. 1000’s of miles without issues. Blue ox bar with ready brake.
TJDave
Eastern WA
2018 JLUR Rubicon
Motorized toy collector
Roadmaster direct connect baseplate mounts. Many years and thousands of miles. Barely noticeable when ends are removed. With the towbar connection under the bumper, no hitch riser is needed with my lifted Jeep.
Jeep Wrangler JL Flat towing set up 20251010_180318
Jeep Wrangler JL Flat towing set up 20250810_082210
Jeep Wrangler JL Flat towing set up 20230928_131117
DanW
I'm going to do this in a couple of years. That looks like a perfect setup for me. Would you be able to show some closeup pics of how it mounts under that bumper?
Thanks!
TJDave
Eastern WA
2018 JLUR Rubicon
Thanks!
The best I've got. I shaved a little off the inside of the winch plate so it would fit in between the Roadmaster mounts which sandwich the frame. I use a Demco Stay-in-play brake, which is great. Previous Jeeps I used the RVI3, which was also great for a portable. The first pic you can see the inside of the Roadmaster direct connect mounts that capture the frame on both sides.
Jeep Wrangler JL Flat towing set up 20230922_172723
Jeep Wrangler JL Flat towing set up 20230922_130735
Desertwolf
Terry
Nevada
1988 wrangler/1993 4x4 xlt 250
I have NSA Tow and Brake life time replacement parts made in usa and i like their Brake set up easy setup
Jeep Wrangler JL Flat towing set up 20260619_133306
