falcon steering stabilizer
OffRoadWarehouse
San Diego, CA
www.offroadwarehouse.com
2018 Jeep JL
Jeep, Shock, Suspension, and Export Specialist
We just installed the SP3 Teraflex Spring kit with the 3.3 Series shocks and 2.2 Series Stabilizer. It works phenomenally! You can get it here
plex
Cincinnati, OH
I just installed my Nexus 2.2. It is awesome! Long windy highways, clicked it to firm and it holds perfect. Off-roading, click to soft and it is amazing!
I wanted to thank jeremyjeep for the info about the bad factory steering stabilizers. Mine was no. X151 it's already been replaced.
The only issue with my steering was when I hit uneven or pot holes in our great Michigan roads the wheel would give me feedback.
What I mean by that is when I hit a pot hole the wheel would shake back and forth in my hand. I got a Falcon 2.2 adjustable stabilizer.
All I can say is it took 95% of the shake out of my wheel when I hit something. You can feel the different settings, I'm using medium most of the time. I also replaced the stock track bar with a JKS Heavy Duty unit. I will also be replacing the lower control arms with heavy duty (non adjustable) fixed units. Tire pressure is right at 38. It drives really great now. My ball joints were also barley (the bottom ones) hand tight, I tightened all 4 of them the first week I had it. I also went thru all the steering components and made sure they were tight. This was my experience I just wanted to share it with everyone. This is a great forum I have learned lot. Yeah I was crawling around under my Jeep looking at all the welds to! So far no recalls.
So glad I bought the Falcon Adj Shock it solved all my Death Wobble problems. Highly recommend with lift big tires
Hey for you guys put on Falcon 2.2 SS, how hard is the installation? Do you need to disconnect track bar to get access to the bolts? (assuming stock track bar)
Bearman95
Chuck
Ft. Worth
2018 JL Rubicon
If no lift you will either have to jack it up on jack stands which is what I did or remove one end of track bar. I have since had the mopar lift installed. I could now remove it without taking the track bar off. The nexus makes for a great driving experience.
Brew211
Peoria, Arizona
2018 JLURM, 2022 392 XR, 2024 F250
super simple install, directions and video from Teraflex made it a breeze. I did not jack up the vehicle, installed on the floor. One item not addressed was I had to get an alignment after, my steering wheel was 90 degrees off.
SpringsJL
Cage
18 JLU
Easy did it on 30 min lunch break. If you have a lift on Jeep you don’t need to remove track bar bolt just use 6” extension where you need to.
Blackwing 55
Tracy
Rock Springs Wy
Granite Crystal JLUR , 05 5.9 Dodge , 2014 Goldwing
I have a stock 2018 JLU with stock 17 in rims and non-lifted. Have 8,000 miles on the odometer and started experiencing something similar to death wobble but on a lower scale, meaning if there are minor pot holes on both sides of the road I get an uncontrollable shake from side to side until I pass the bumps. My jeep originally drove much smoother and I didn't feel those bumps as much as I do now. My question is I ordered the teraflex falcon steering stabilizer 2.2 adjustable but they also make a non adjustable, should I have ordered the non adjustable since my vehicle will not be lifted?
I have a JLUR with the Mopar 2" lift on the stock 33" tires, I also started getting the steering shimmy at about 7,000 miles and it progressively got worse until it wasn't anything short of the death wobble, tried to order a Fox steering stabilizer but they were backordered, I just installed the Falcon 2.2 yesterday, and today I've been driving all over the same roads that would trigger the shimmies. It is fixed !!! not a sign of wobble, I set the stabilizer on the medium setting and haven't touched it since. so I would guess the non adjustable unit would work just fine.
SpringsJL
Cage
18 JLU
^^^ this is awesome glad it fixed your problem as well. The medium setting is awesome for city the firm really helps on the highway.
vtech243
Ian
Boston
Wrangler JL & BMW X3 M40i
Excited to see everyone getting results! Ordered the Falcon adjustable today. I’m at 6k miles with Mopar 2 inch & 37 KO2. Started getting shimmy going over bumps (very similar to everyone here) last week. I had my shop re-torque all bolts to spec today which helped with the “loose” steering feeling I was getting but did not solve the highway bump shimmy. My stabilizer is one of the “bad” ones so looking forward to swapping it out next week.
mer43
Mesa, AZ
'18 JLUR
I tried to bend my stock dampner into a banana on the rubicon trail. I picked one up from River City Offroad for a great price, and have been more than happy. The one drawback, is that it sits in nearly the exact position as stock, so it's only a matter of time before I noodle this one too.
Looking into some steering upgrades, and will try and remove it from the bracketry. Hopefully, I can get it top-mounted over the tie rod. It would be a damn shame to ruin such a nice unit.
Running on firm onroad, and soft offroad, on 37's and a RC 2.5 lift.
RedJLUR
Michigan
2018 Wrangler Rubicon Unlimited
Yes, you need to unhook the end of the track bar on the passenger side. You need to get to the bolts holding the original steering stabilizer bracket to the axle. It's not that bad. The Falcon 2.2 comes fully extended. With the wheels fully turned its still to long to line up with the spacer and other brackets that come in the kit. The most difficult part is compressing the stabilizer to bolt it up. You cannot push it in by hand! Warning, there is a seal on one end with two little springs, be real careful when trying to rotate it to line it up. I ended up using a long screwdriver thru the eye and into the bracket, pulled on it and the stabilizer finally compressed. Once you brake it free it will move freely. There is a video on YouTube of the installation. Well worth the money, I can't stress that enough. My JLUR steers great with next to zero wheel shake of any kind over any terrain.
Good luck!
Grant
Grant
Douglasville, GA
2019 (Ordered) JLUR, Punkin’, 3.6 Auto,
I would certainly appreciate it if you could take some pics showing the height from the side of JL. I am probably getting the TF SP3 for my JLUR, and would really like to see the result. — Grant
GraniteRubiGA
Jonathan
Marietta, GA
Executive
I installed my 2.2 today and it was extended too long. I had my wife turn the wheels to the left and I put it on the tire to compress. She turned it back to the right and it fit perfectly. My steering may have been a little loose, but it is night and day how much better it is now!
Jeep Wrangler JL falcon steering stabilizer EBE6D917-514D-4429-9FF3-42BC7F682159
Jeep Wrangler JL falcon steering stabilizer D435D883-EA85-4CF1-8633-B70E3B09BF34
vtech243
Ian
Boston
Just wanted to update this thread with my experience. Put on the adjustable 2.2 stabilizer last week and it has been a night and day difference! I've done a ~300 mile round-trip (on terrible roads) twice with 0 shimmy. Medium works fine for me even on the highway -- I probably could have got the non-adjustable one and been fine. Highly recommend doing this with bigger tires and/or lift.
