EVO 3.5 installed, but....
SnowDawg
Montana
2019 JLUR, 2022 JLUR, 2018 Raptor, 2022 TRX
So I installed the EVO Enforcer 3.5+ with Kings, but I seem to be sitting low in the rear. I have the hinge reinforcement and 37 with beadlock on the back so I'm heavy back there, and no winch yet upfront, but still, my rear wheel gap seems awfully small. I'm curious what input or thoughts people have. Is it normal? If it's not thoughts on what it could be? I talked to EVO and they asked for pictures, but go figure I never heard back.
Jeep Wrangler JL EVO 3.5 installed, but.... IMG_3967
Jeep Wrangler JL EVO 3.5 installed, but.... IMG_4002
Jeep Wrangler JL EVO 3.5 installed, but.... IMG_4005
Jeep Wrangler JL EVO 3.5 installed, but.... IMG_4006
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
Add a winch and plate or aftermarket bumper and it will settle down. They set these springs up with the assumption that you will add heavy accessories to the front and rear. The rear looks just fine to me. The front just needs some weight.
2Wheel-Lee
Lee
Orange County, CA
2020 JLUR, 2006 Dodge Ram 2500 CTD, 1986 Suzuki Samurai, 1975 Datsun 620
If you look at the fender body lines, the front opening is taller than the rear.
Though the front end is a tad higher when looking at the overall body line, the front may go down when you put a winch on it. Also, springs tend to settle a bit.
BTW, I will also be installing the EVO 3.5 lift when I get my JL.
SnowDawg
SnowDawg
Montana
Thanks guys. It's nice to get some others input on these things....you know, once you see something you can't unsee it.
moodywizard
Lyle
2019 JLUR
Hows does it ride with the kings? I installed same lift kit with fox shocks and its a bit bouncy.. I have the evo quarter pounder with warn 10s in front, my front is a little lower than rear (opposite problem you have lol). Going to try a 3/4 front coil spacer.
2Wheel-Lee
Lee
Orange County, CA
Which Fox shocks did you use? I was thinking about using the new Fox Factory Race 2.5 series that they recommend for 3.5-4" lifts.
If yours is these shocks, where do you have your adjusters and how much nitrogen pressure are you running?
SnowDawg
SnowDawg
Montana
I'm definitely happy with the kit, rides great with the Kings, I'd say very similar to stock.
I do rub pretty hard with the provided bump stops, new fenders or removing the lower half is definitely going to be required. Cheers
moodywizard
Lyle
2019 JLUR
Fox 2.0 off the shelf tuning. 2.5 with h adjusters would be nice but not sure long-term of I'll go long arms and coilovers so got this lift kit for now. I've had nitro shocks/coilovers before on another build. You usually run around 200 psi, you can adjust to make the shock softer or firmer basically without going too technical.
moodywizard
Lyle
2019 JLUR
@SnowDawg what length are your control arms? What the instructions say to start with? I added about 1/2inch to those numbers and the front passenger coil is rubbing the bump stop. Going to play with it later tonight...
SnowDawg
SnowDawg
Montana
I'll check. Give me a day or so. Anything else you want me to check?
2Wheel-Lee
Lee
Orange County, CA
What size tires are you running? Look like 37s? How tall of bump stops? Wheel backspacing? Thanks for the info. Yes, removing the fender liners will surely help.
2Wheel-Lee
Lee
Orange County, CA
Ah...the "long-term" debate. I keep thinking the same. Though as you know, there are compromises with coilovers (mainly noise and maintenance). When I get my JL (JS status of today), I'll probably start with either the Fox or King 2.5. I may end up with coilovers, but I want to give a basic setup a shot first.
I'm quite familiar with nitrogen pressures (I have my own setup since I rebuild all my own shocks on my vehicles), but I was just wondering if you did have that type of shock, as I was thinking you may have been too high or low ("bouncy" is vague and could be either).
SnowDawg
SnowDawg
Montana
That's it whenever you get a chance, thanks!
I kept my stock Front uppers and rear lowers, so the Stage 3 kit, since I was throwing so much at the Jeep this go around so the measurements on those are obvious. My Front Lowers are roughly 24 1/8 to 24 1/4 (manual has 1/8 listed but I seem to be touch longer). Rear uppers are as stated in the manual at 17 1/2.
