ESS started working again
White Rubi
Randy
Louisiana
JL
So I just bought my JL used and it had the ESS light on which I was fine with. I recently used the JScan to change my tire size and unlocked the navigation. Since then the ESS light went off and the engine stops at red lights again. What did I do wrong and how do I fix it?
multicam
Tanner
Alaska
2018 4Runner, 2019 JLR
It’s possible that the Jeep’s batteries are on the fritz and sitting on a dealer lot exacerbated that problem. Then after driving it for a while and using the JScan, the batteries got enough of a charge for ESS to start working.
Fortunately you’re not stuck with it. You could buy a product like Smart Start Stop, a JL Tazer, or something else to disable it. Or disable the aux battery altogether (search the forums).
jeepoch
Jay
Longmont, CO
2019 JL Wrangler Sport S 3.6L Auto 2 door, 2.5" lift, 35s
Not to sound incredulous, but I'm amazed that people will spend hundreds and consume considerable hours to do anything except press the little dashboard disable button.
Also the EVIC on the cluster has a page to show ESS status. Typically when the ESS stops working for me, the reason given is usually "Battery Charging" or "Battery Protection Mode" which is a great indicator of an aging battery. Either the Main or the Aux (or both).
I just recently replaced my main and the ESS has started working properly again.
For the record, I don't mind the silence when stopped at traffic lights.
Jay
Haberrj
Canada
2020 JL
Jay
This is so true about the money people spend to disarm ESS. All I did was lift the hood and unplug it. I don’t mind that little notification light on the dash.
White Rubi
Randy
Louisiana
JL
What did you unplug I'm new to the Jeep scene.
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
You can...unlock nav?
Well that's pretty neat!
Haberrj
Canada
2020 JL
When you open the hood you will see 2 plunger types switches approximately over the drivers side headlight. If you search on YouTube there are excellent videos that will show you how it’s done.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
That little notification light on the dash is an indicator for more than a fault with ESS. Sometimes other issues like misc. misfires will cause ESS to be purposely disabled (turning on the light) before the misc. misfires trigger their own alert. By causing the light to be on all the time, you may miss out on important notifications.
SilverSurfer
Heinrich
South Africa
2020 JL Rubicon 3.6 8-speed Auto
How can I get to this page you are referring to that shows the ESS Status.
Haberrj
Canada
2020 JL
You are probably correct no doubt. This is my 5th Jeep my 4th 4 door unlimited. To tell you truth if I had known about this 2 battery system that controls the ESS and any other functions I certainly would not have bought it. After reading on this form all the headaches that this system can cause I am seriously thinking of getting rid of it, and to make matters worse the techs at the dealers can’t even fix them when anything happens. I am quite sure other makes have their issues also but nothing compared to what I have been reading here. Anyway love the Jeeps just can’t handle all the crap that seems to be on with the new ones.
bthomp
Bill
Fort Collins, CO
2021 Wrangler 392 XR, 2023 Rubicon XR, 2010 Wrangler X, 2014 Mustang GT
IT Operations
It's on the center console menu options. Scroll past tire pressure, gas mileage, and eventually you get to a ESS status page.
aldo98229
Aldo
Bellingham, WA
Market Research
Pressing the ESS button is NOT going to give your batteries extended life. The OE batteries are trash, ESS button or not.
The sooner you replaced those batteries with an aftermarket brand, the fewer problems you will have, and the greater peace of mind you will enjoy.
Yawnie'sPapa
Bill
Central Iowa
'22 JTO, '23 JLUR, '82 SX4, '73 P. Cardin Javelin
True - keeping them charged, topped off, will extend the life.
Short drives - 30 minutes or less, letting it sit for days at a time, stuff like that - that's battery killers.
Worse on these OEM Jeep batteries, but bad for ANY battery.
Even if you buy great batteries for your Jeep - the best thing you can do for them is to drive the vehicle, not let it sit, and don't drive it 30 minutes a day and park it.
If you don't drive it and have a commute to work that is so short you could walk or use a bike, then you need a battery tender.
IMO, lifespan of an original Jeep battery is going to be roughly 3 years and that's if you don't let it sit, or if you drive it enough.
It truly is amazing that people spend hundreds to disable something that simply annoys them, no other valid reason.
Haberrj
Canada
2020 JL
I know that what you are saying is correct but it’s just the disappointment that I am feeling after enjoying so many good years in Jeeps. Most of the issues I have been through as the saying goes it’s a Jeep thing right. Tell me do you know what the popular replacement batteries that are being used these days.
