ESS light came on after having key fob programmed
Butch15
Butch
Santa Rosa, CA
ā€˜19 JL Sahara
So I took my 2019 Sahara to the dealer to pick up a spare key that I had ordered 6 weeks ago and get it programmed. I got about 3 miles away from the dealer when the dreaded ESS warning light came on in the instrument cluster. Drove straight back to the dealer because it had never happened before. Service advisor said they are replacing the aux battery (for free) but I will need to drive it for awhile for the computer to relearn everything (shift points etc) Is this correct? Should I replace the main battery at the same time to avoid any further issues? FYI this Jeep is bone stock, 49k mile and I’ve only owned it for 2 months. Jeep only came with one key, otherwise it never would have been in a dealership service department. I have a good mechanic that I’ve been using for over a decade….my mechanic did a thorough pre-purchase inspection before I bought it.
jludave
The Isle of Long
IT Manager
It’s possible if the vehicle was without power for a while.
Yes. Always replace both, unless you plan on bypassing the aux.
Butch15
Butch
Santa Rosa, CA
ā€˜19 JL Sahara
Thanks for the input.
Service manager wouldn’t admit to disconnecting battery or even that it was related to the programming key fob, but did replace the aux battery for free as a ā€œgoodwilā€ gesture (including labor). I will replace the main battery tomorrow after work and kick the can down the road as far as bypassing the aux battery.
AndySpill
Andy
Pittsburgh
2018 JL Sahara
