Ess battery change
elf883
steven
NY
2024 jlu willys anvil
stationary engineer
Or do I have other electronic issues.
have you done anything to the jeep to make you think u have other issues?
any upgrades ? lights ? coolers ? anything to make you think this?
any parasitic draw on the battery?
its the battery
  • Like
Reactions: J0E
Joeshek
Hazle Township
2018 rubicon
its the battery
No mods whatsoever..
elf883
steven
NY
stationary engineer
do as @Fudster mentioned , it will be the only way to tell for sure .
but i can almost say its the battery
keep everyone posted on the outcome
  • Like
Reactions: J0E
Joeshek
Hazle Township
2018 rubicon
Will do ..
Thanks for all of the replies
It's appreciated
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
Here is the battery
And here is the voltmeter reading
Have you reset the battery sensor before now? If not, it's reset now with the battery removed. Make sure the battery is charged, put everything back together and see if it works now.
  • Like
Reactions: J0E
Joeshek
Hazle Township
2018 rubicon
I thought it reset when I disconnected the battery to replace the aux battery.
And like I said earlier.. it worked on the way to work but coming home it was back at start stop not ready.. battery charging
Jebiruph
Jerry
Iowa
If it wasn't removed from the main battery or had the connector unplugged, it wasn't reset. Just disconnecting the ground cables from the battery will not reset it.
Joeshek
Hazle Township
2018 rubicon
Hummm..
So.it wasn't reset then..
Joeshek
Hazle Township
2018 rubicon
Ok.. update
Had battery at garage.
Saying everything is just fine.
Load tested and whatever else they do.
Again saying it's fine.
So I guess when I get home I'm going to put it back in and see what happens..
Everything should have reset since it was out all night..
Joeshek
Hazle Township
2018 rubicon
Now I'm second guessing the aux battery change.
What else can be causing this.
elf883
steven
NY
stationary engineer
What’s the voltage at now ? I’m still gonna say it’s the battery , your not leaving anything plugged in or turned on I’m sure so hmmmm
Mark Elliott
Orlando
2026 Rubicon X 2-door
Hummm..
Earlier today had same voltage and someone said it was fine.... I'm so friggin confused! Lol
My main is only 13 months old..
It shouldn't be going bad already.. or something else is wrong.. this shouldn't be eating batteries like this... do you think?
Actually had my main battery replaced under warranty right before it ran out, 13 months later I had to replace it, dead as a door knob. Was going to replace my aux battery but I don’t have one, found that out after I removed the fender and dropped the box. I guess I have the 48V battery next to the driveshaft since I have the 2.0L turbo.
elf883
steven
NY
stationary engineer
That’s what I have and also had to do. But I purchased my own battery , screw mopar battery.
