ESC Problem - Light on
Stolar13
Łukasz
Poland
Wrangler Sport S 3,6 - 2dr
First time seeing this thread and reading through the posts.
I see a bunch of battery talk, but nothing that addresses your axle swap. You pulled 3.45 geared axles and replaced them with 4.10 Rubi axles? Did you reprogram for the gearing change? The same with the larger tires? Also, was your steering wheel centered after the lift, or is it cock-eyed? The wrong programed gearing and a crooked steering wheel will trip esc.
Hi
I did everything you wrote:
Reprogramming:
- Change the gear ratio to 3,73 (I have Rubicn axle from european Diesel Jeep)
- Change tires size
Additinal I Centered the Steering wheel
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Hi
Reprogramming:
- Change tires size
Oh OK, was just surprised that no one had questioned that. Process of elimination.
So, had did the new battery work out?
Stolar13
Łukasz
Poland
Unfortunatly no, I have no malfuction "TSART/STOP Battery Charging" but ESS still doesn't work and still ESC light on
Mike Delgado
Mike Delgado
lake Wylie, SC
JLU 2020
I know how to adjust the steering but how do you get the light to reset or turn off on the dash?
Headbarcode
LI, New York
Just drive it around with a straightened steering wheel and it'll reset itself. Mine shut off very quickly after the adjustment.
Mike Delgado
Mike Delgado
lake Wylie, SC
JLU 2020
I just adjusted steering drove about 15 miles and nothing. Will check again tomorrow. Thanks
