Electronic throttle control/stability control
Edryan1977
Ed
canada
2021 Wrangler Sahara Unlimited Sarge Green
I have 2021 wrangler Sahara unlimited V6, barely over 20,000 kms on it. This morning I had a CB radio installed, nothing crazy, mounted on passenger side of center console towards the dash with power cable to the battery, antenna mounted on driver side, nothing to the fuse box. simple install. The jeep was perfect when I drove it to the shop this morning, went to pick it up after the install, fired it up and got warnings for the electronic throttle and stability control, check engine light was on and I couldn't get over 10-15 km/h. I tried disconnecting the negative battery cable for 30 min give or take and no change. Called dealership and they said it was in "limp" mode and needed to be brought down, so I called roadside and away she went. ( 2 hour trip to dealer). I started reading other posts on here about somewhat same issues. I cant see the radio install affecting anything because nothing was modified, no wiring or anything touched. I read a couple posts about possible RF waves causing issues? Or I thought maybe because it was mounted to close to the transmission causing computer chip interference??? I have no clue and hope its nothing crazy bad... Any suggestions out there would be greatly appreciated
Edryan1977
Ed
canada
I turned it over multiple times with no issue while trying to reset the codes though..
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Nicked a wire during the install maybe.
Or coincidence maybe.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
I didn’t say it stayed dead, sorry it wasn’t clear. Check codes. Expect a bunch of low voltage / communication codes.
Of course, could be a bad throttle body, or any number of other problems. I wonder if we use the same TB as the 2.0 and 2.4 in the smaller Jeep brand vehicles. Very common failure on those.
Do you have Etorque or no?
Edryan1977
Ed
canada
Just to update everyone, I got a call from Dodge today and the radio install was good, no issues found to be causing anything. They did find a broken wire on the accelerator and ab issue with the PCM. There were also 2 recalls completed. I will get more details when I pick it up tomorrow and let you all know for future reference.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
And that kids, is why I hate working on electronics. Lol. And I'm an electronics tech. Glad it's sorted.
