Electronic Throttle Control light
Mr. Redhawk
Yeagertown PA
2019 Jeep Wrangler JLU
2019 JLU with about 40k miles. Started up the other day and got a warning for my Electronic Throttle Control (ETC). Drove around a bit and restarted without an issue. I do notice the ETC warning light is on the dashboard for a second when first starting up but then it goes out. Any insight on this?
  • Like
Reactions: Gus
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Electronic Throttle Control (ETC) Warning
Light
This warning light will illuminate to
indicate a problem with the ETC
system. If a problem is detected while
the vehicle is running, the light will
either stay on or flash depending on the nature of
the problem. Cycle the ignition when the vehicle
is safely and completely stopped and the
transmission is placed in the PARK (P) position.
The light should turn off. If the light remains on
with the vehicle running, your vehicle will usually
be drivable; however, see an authorized dealer
for service as soon as possible.
NOTE:
This light may turn on if the accelerator and
brake pedals are pressed at the same time.
If the light continues to flash when the vehicle is
running, immediate service is required and you
may experience reduced performance, an
elevated/rough idle, or engine stall and your
vehicle may require towing. The light will come
on when the ignition is placed in the ON/RUN or
ACC/ON/RUN position and remain on briefly as
a bulb check.
If the light does not come on
during starting, have the system checked by an
authorized dealer.
  • Like
Reactions: Gus
Spank
Mine has done this (where it pops up for a brief second, then vanishes on start) for forever now. It's random, too, and doesn't do it all the time. Regardless, I haven't had any problems.
KingZo88
Lorenzo
Las Vegas
2020 JL Rubicon 2 door
Going to wake this thread up… i just noticed the etc light comes one while vehicle is starting but goes away when started. No issues while driving or anything.. should I be worried and take to the shop?? Im at 16.2k miles
jaybirdtig
Jaybird
Pennsylvania
2020 jlusd
Also got this message recently and CEL for several days. 2020 3.0 diesel@30k. The shop said they’d start with the battery. But no other advice. Anyone get a resolution?
Gus
Ontario GTA, Canada
wrangler 2018 JLU Rubicon
Same here exactly on JLUR 2018 took it to teh dealer they didn't have any codes.
Did you figure out the issue yet?
Thanks in advance
oldcjguy
Jim
Central FL
16 Challenger Hellcat, 19 Challenger Scatpack, 20 JLUR Recon
Software Engineer
AFAIK On a gas motor it's normal during start up. It should turn off after the motor is running. On a diesel I have no idea.
SnowyJeep
Canada
2020 Jeep JLU Sport S
Our Jeeps (and all modern motorized vehicles) preform a "bulb check" on start up or when you cycle the start button to Run. This is a quick test to ensure the dashboard warning lights/wiring are working properly. If your Jeep shows the warning briefly on start up then it's likely just doing that check. At least that's what I assumed with my Jeep; it has shown that warning on start up since the day I bought it. In over a year of ownership, my driving experience has never indicated that there was actually something wrong with the ETC.
  • Like
Reactions: Gus
Gus
Ontario GTA, Canada
I only started noticing it few months ago, when I start it, the big flash on the dashboard with the red symbol pops up and disappears immediately, couldn't catch it on video yet as it happens randomly not too often lately.
Not sure if it is related to hot temperature or not though. cause that when I started noticing it.
otherwise haven't noticed anything.
The dealer did mention that it could be a system check at the start.
Thanks for your feedback,
SnowyJeep
Canada
From what I'm reading, not seeing it on startup is unexpected behaviour.
GATORB8 quotes the manual...
The light will come
a bulb check. If the light does not come on
authorized dealer.
abubakar
Abubakar
Ottawa Ontario
2018 Jeep Wrangler Sahara JLU
Anyone figure this out? I get the "Service Throttle Control" on startup with the chime and then it goes away completely
