electrical issue
jeepmom19
jaclyn
michigan
2019 are jeep wrangler unlimited sport
i have a 2019 jeep wrangler unlimited sport and it seems to be having alot of electrical issues ever cents the temperature started getting in the 70s it tells me no bus lost communication and a lot of stuff has anyone have had this problem? if so what was the diagnosis?
americonium
Abe
NY
2018 JLUR Black
Engineering Technician
Have both of your batteries checked. If one is bad, replace both of them.
jeepmom19
jaclyn
michigan
my main battery is new and i cant find the other one cause its not where it should be under the hood
americonium
Abe
NY
2018 JLUR Black
It's not under the hood. It's under the fuse box, or behind the passengers front fender liner. If you changed one and not the other, you might have issues caused by the other battery.
jeepmom19
jaclyn
michigan
its at the dealership right now its been there for 2 weeks and they said oh the tech is trying to figure it out
americonium
Abe
NY
2018 JLUR Black
Well, it's in Jeep's hands now.
Nitehawk92
Vandalia, Ohio
23 JLU Reign Rubicon 14 Mazda, 22 Hyundia Santa Fe
Retired Air Force Current Civil Service Civilian.
If your Jeep still has the original factory batteries have the both replaced. Replace them both at the same time. Before you pay anybody to do anything to it, replace them...
jeepmom19
jaclyn
michigan
we changed the main battery but the other one is not under the fuse box or anywhere around there its a 2.0 turbo i heard someone say i could be inder the jeep i dont know
oldcjguy
Central FL
Software Engineer
There are a couple of star connectors in the jeep. These are where the different controllers get connected to the CAN bus in the vehicle. One is behind the glove box. Check there for loose wires or a cracked connector. I think there is another one near the passenger side rear wheel well inside the jeep. They are just plastic bars with connector ports. It's not incredibly uncommon for one to crack and cause errors. It could be just your dash cluster losing communication. Get a code reader and plug into your OBD port and read any stored codes. That may point you in a direction as well.
running_man
Andy
2019 Rubicon JLU, 2003 BMW Z4, 2012 Lexus ES350
You probably have the etorque so you don't have the small aux battery under the fuse box. There is a large battery under the rear passenger side inside the frame rails, that's the only other battery you'll have. I'd follow oldcjguy's suggestions, seems like a good place to start since you've changed your main battery.....
speedymart
mephis
2021 jl
not all 2.0ls have two batteries; it's possible you have an e-torque model without it
