Dumb Lift Question
MtCamper
Ken
NW Montana and Yuma Az
2018 JlUR White Rubi, 2022 Chevy 3500, 2016 27-5L
Retired, Snowbird
OK, I know this stupid question. I'm going to 35s when I re-tire my JLUR. I'm afraid that still won't give me enough lift to clear those occasional obstacles the 2 doors can go over. I don't really want to raise the Jeep permanently, my wife already complains about how hard it is to get into. I have on board air, can I just add front and rear airbags and inflate them to gain a couple inches of body lift just to clear a single obstacle? I've had airbags on trucks to level loads and could get several inches of lift. I know guys who ran front airbags to level out snowplows. In both those cases the lift was to get back to level. Can I use the same airbags to get body lift above level? Thanks
AeonFrost
Xylan
GMT-5
2018 JL Sport S Unlimited Granite Gray
Your rubicon should have no problem going over obstacles on 35s without a coil shock lift.
You can get a rocker with a fold out step so your wife won’t complain about being hard to get in the vehicle.
if you are talking about air suspension, that would be an idea but not a cheap upgrade.
MtCamper
MtCamper
Ken
Retired, Snowbird
No, I'm just asking about regular airbags that are designed to level a load. No I can't go over some of the obstacles I encounter here in the Arizona desert with my 4 door because I end up being a teeter-totter and need a pull. I'd like to get an occasional 2" body lift to clear a few more of those big rocks and was wondering if standard (cheap) airbags would do the trick.
MtCamper
MtCamper
Ken
Retired, Snowbird
That's the idea but that's the spendy full suspension AeonFrost mentioned. I'm curious more about the Firestone load leveling suspension. If the airgabs are empty and you inflate them fully how much lift do you get?
Rubi-Zero
Nashville, TN
JL Rubicon , Audi S5
A body lift isn’t going to help you clear the rocks that you are getting stuck on. A body lift will only lift the body from the frame.
I dont have much knowledge on airbags other than I have seen them used on the rear springs to help with load when towing.
You may want to look into a 1.5 lift to go along with the 35’s and find some steps to help your wife get in the Jeep.
sorry not much help on the airbag info.
aldo98229
Aldo
Bellingham, WA
Market Research
Land Rovers come with air suspensions that lift the truck. They are notorious for breaking down. On the rare occasion you meet a Land Rover owner on the trail, he comes with an endless supply of stories about mechanical breakdowns.
Jeep Grand Cherokees Trailhawks and Ram Rebel pickups also come with air suspensions to lift the truck. Although those appear to hold together better than Land Rovers’.
A side effect of air suspensions is that when you inflate the airbags to gain clearance, it also makes the suspension stiffer, reducing articulation.
Good luck.
Fully lifted
Jeep Wrangler JL Dumb Lift Question in018_087
I wouldn't go with an airbag add-on. If you're absolutely convinced you need more clearance at the trade off of other things, get a good lift system, the whole system and get your wife some retractable steps.
I like to keep my roadable vehicles relatively low to keep the center of gravity low and maintain road handling, since I drive my Rubicon on the road everyday and off-road a very small percentage of it's life. Besides, the dogs need to get in and out. If I had a dedicated off-road vehicle, I'd lift it.
Biohazard
Nathan
Bristol, TN
2018 JLUR (sold May 2020); now own 2020 trd pro Tacoma
Bad idea. Complicated, won't help. I agree with the other guys, lift a little and add some steps for your wife.
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
look at belly skids then
you are never realistically get a 2 door break over unless you go bigger on lift and tires, which you do not want to do for egress reasons
but first take the jeep off road see what the trails your plan on running are like and what need to change to make the jeep better to handle those trails
