DSTRAC support group
my_0range_crush
Steven
Dallas
2018 Jeep JL Sahara
Hey how’s it going everyone. So I was a big supporter of dstrac when I first got the axles. Well they suddenly became very unhelpful with getting the axles fixed. I’ve had a few people message me trying to get them fixed so I’m on here to help anyone find part or ways of fixing them when they start to break down.
The rear pinion seal has been leaking since day one. I replaced the seal 3 times and it keeps leaking. I found that the breather tube fitting was WAY too small so it was creating a lot of excessive pressure and making the seal fail. I replaced it with a 5/16” hose barb to 1/8 NPT male fitting. The rear pinion seal is from a Dana 70 axle. I was able to get one on Amazon. I believe the rear axle is based off a ford F350 axle so we might be able to get parts fairly cheap. The rear locked has similar parts off of a ARB locker too.
if anyone has any more tips or info please add it on here to help others out.
word302
Oregon
JLU
Bummer to hear. This is exactly what I was afraid of.
my_0range_crush
my_0range_crush
Steven
Dallas
2018 Jeep JL Sahara
yeah it’s not great to have to source all the parts now when/if they break. They do come with 1550 u joints and 40 spline axle shafts so I hope those don’t go out any time soon
911turboz
Denver, CO
21 392 Rub, 13 JLU, 97 TJ, 76 CJ7, 74 CJ5, 06 LJ,+
VP Land Rover Denver
Partial parts list for DSTracs… please add to it for future reference for those of us running these axles
Pinion Seal - National 9316
Rear Calipers 18-B4790 at Rock Auto
Ring and pinion is standard D60/70 29 spline (pinion measures 9 5/8” tall)
Hubs are AVM 40 spline
Rear axle seals are 95x10x70 - had to order from Bearings123 online
Rear pinon bearing/ race - Timken SET81 (HM88510-HM88542) and Timken SET83 (HM803149 - HM803110)
Rear carrier bearings HXHV - 382S & 387A
Rear shim kits SK706213 for D70 (55019)
Rear piNiño preload shims SK 34801 for D70 (55015)
Front axle stub shafts are 1550 u joints
Anyone know what pads fit the front Brakes?
Anyone know rotors front and rear that are compatible?
Please add to this for known parts to help everyone when needed…
Stefanoramon
Stefano
Greenville texas
2012 JKU 2018 JLUR
Front brakes are 2015 tacoma calipers/pads with the quad piston option
Rears are 2000s super duty front calipers/pads
my_0range_crush
my_0range_crush
Steven
Dallas
2018 Jeep JL Sahara
Can you send the link for the rear axle seals? I can’t seem to find anything on bearings123 under 95x10x70
Jrellis
Jr
Wyoming
2022 gladiator
Does anyone know what ring and pinion gears these use! Can you get a set from yukon or somewhere similar
RMS_AZ
Ryan
Arizona
2021 JLUR 392, 2021 JLUR 4Xe
Here are the exploded views and some basic instructions for the axles. Side note the spindle nut can be swapped out for a N11 nut and lock washer. Found them over at Kartec.com
