VTL
sorry but you dont need to build a frame to use portals, if this was true nobody would use portals. The point of using portals is to get true ground clearance with a smaller lift. This will keep stock angles so that you have a good ride on road and in the trails.That’s just it, so you’re going to go back to basically stock-height suspension and then have limited room for articulation before these things start hitting everywhere. It’s not really practical unless you’re building a frame designed to work with the axles. If you’re looking for turn key setup for long arms Dynatrac will ship your axle with the Rock Krawler bracketed all setup for you. Yes they’re expensive but if you’re not going to do some of your own fabrication it’s probably cheaper in the long run.
