What does anybody know about these Dstrac axles?
VTL
Wilson
Orlando
JL
That’s just it, so you’re going to go back to basically stock-height suspension and then have limited room for articulation before these things start hitting everywhere. It’s not really practical unless you’re building a frame designed to work with the axles. If you’re looking for turn key setup for long arms Dynatrac will ship your axle with the Rock Krawler bracketed all setup for you. Yes they’re expensive but if you’re not going to do some of your own fabrication it’s probably cheaper in the long run.
sorry but you dont need to build a frame to use portals, if this was true nobody would use portals. The point of using portals is to get true ground clearance with a smaller lift. This will keep stock angles so that you have a good ride on road and in the trails.
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
You won't want full hydraulic steering for an on road application. You can drive full hydraulic anywhere but for a mostly street driven rig I'd stay away from it. Mostly for the clockspring in the steering wheel. It won't stay alive will full hydro.
No reason you can't run traditional steering or steering assist with these axles. Just have to set yourself up for it from the beginning.
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
Agreed. You'll run stock suspension but net the lift the portals gain you. You'll just have the same amount of suspension travel you would when stock. Should that be of concern.
word302
Oregon
JLU
You do realize up-travel is a thing right?
JimLee
Jim
Too damn close to Death Valley
'19 JLU
Jeep Wrangler JL What does anybody know about these Dstrac axles? 1sz3bh
Seriously, now is the time to jump if you are looking at "big boy" axles. The price of metals is skyrocketing, and quickly because of worldwide shortages. Hell, Dynatrac can't even get pumpkins from the foundry, I'm 12 weeks into a 6-8 week lead time on a set of 60's with a big question mark on actual delivery date. I'm just glad I got my price locked in when I did. These shortages will probably affect all manufacturers no matter where they are based. I'm pretty sure there are only a few foundries worldwide that make pumpkin castings, just like coil springs. If you need something large, that is made of metal, now is the time to act.
MarkY3130
Denver
2019 JLUR
You buy them and I'll help you get them under your Jeep.
I might have to take you up on that! I work in Thornton so I can't be too far from you. I am targeting paying off my house in August and then I'm planning on axles. My employment is highly commission based which makes things tough to plan around sometimes, but I believe this year is the year
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
I've done many different custom axles so this isn't outside of my abilities. Always looking to learn something new though. :)
