Driving on the beach, concerns.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I have been invited to drive on the beach in NC but I am reluctant to do this due to concerns about the salt/corrosion. I also have fluid film on the frame and undercarriage of my jeep. I am concerned about the sand sticking to the fluid film. I have skinny, pizza cutter tires. I'm not sure how they will perform in soft sand. I guess I'm wondering if a beach ride is worth it.
Any advice or suggestions would be appreciated.
Dlit
South Florida
Rubicon JL Recon
It is worth it…tires aired down will not be a problem. Wish it after, ammo sells a product that neutralizes salt. I use that wait a bit wash again and reapply. Use your ride
toothirtyj
Indy, IN
'21 Hellayella JL Willys, 3.6L/6MT, 4.10's
LE
Stay out of the water (puddles, obviously the waves, etc) at all costs.
Beach riding is fun, so go for it!
Centurion07
'MERICA
2019 Rubicon 2-Dr
I've been all over the beach & bay shorelines, puddles & all. That said, I don't have fluid film. Wash the hell out of it and rinse, rinse, rinse.
Also, my tires are not pizza cutters. (But I do like a good pizza.) Just be mindful if things start feeling soft/deeper, and stay clear of dunes. You're not riding solo, so you should be fine.
Stetson
Salt Lake City
2019 JL Sahara, 2023 392 Rubicon, 2020 GMC 3500 Denali
Project Manager
For sure! Use your Jeep and have a good time.
although I have never been to the beach in my Jeep, it is bathed in salt and brine every winter in Salt Lake City. The beach cannot be any worse than that!
Stetson
Boatbuilder88
New Jersey
'19 Wrangler JL
F-16 Engineer (retired)
Air down and hose off the undercarriage several times afterwards. Your Jeep will be fine.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
I'll reiterate what the others are saying. Have been on the beach a number of times, stay out of the surf and you'll be fine. Turn off traction control!! You shouldn't need to air down, but depends on conditions. You'll have a blast. Just wash it off when you're done, if you're lucky driving in the rain will do most of the work.
Punkn89
Alex
Maryland
2019 Wrangler
I’ll be down there 9/15-9/22! Super excited! Although, I’ll have the Grand Cherokee, but it has Michelin Defender LTX MS2’s. Going with a Jeep and Bronco crowd to Carova.
As everyone said above, air down to a minimum of 20 psi. Definitely wash it thoroughly. I’d also suggest bringing recovery gear - straps, traction boards, rapid deflators, onboard air (they do have pumps there too), and a travel shovel.
You do also have to buy a parking pass if you are going to hang out on the beach for a while.
wcjeep
Earth
YJ with stuff. JL 2dr Sport
After beech fun has concluded recommend a thorough rinse of the under carriage. Get every Crack and crevice. I use normal hose nozzle pressure. I do not use the pressure washer. Then take it to a local carwash that includes undercarriage wash.
2nd 392
Ca
Invited, hmmm, sounds like you won’t be alone so go for it. I was playing in the small dunes by the river with the 3A when it took 2 Jeeps and an FJ40 to get me out of a quicksand hole. It took all 4 using all the winch cable, strap and chain we had to get the FJ’s wheels on solid ground to do it. What a F’ing mess. :facepalm:
But it was an “unsalted” mess 🙃
Remorseless
NC
You'll be fine. Just air down to like 15-18 PSI and go for it. Tip on the sand - a little bit faster is often better in the spots where the sand gets churned up and makes the Jeep bounce. By going a little faster you end up riding on the peaks of the undulations instead of riding a peak and then crashing into the valley.
As for corrosion - modern metallurgy is great, just give her a pressure washing when you get home and it'll all be good.
Terrymo
Terry
2023 JLURXR 3.6 ET
As others have said, bring a shovel and air down so you don’t have to have a Subaru or a Prius get you unstuck. That would be embarrassing.
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
Air down to 18 or so PSI. 4h traction control off.
What I do is I put a water sprinkler under my jeep and let it run for a few hours. You will be amazed at how much salt and sand will get washed off.. I use a sprinkler after mudding too.
You want the sprinkler like this.
Jeep Wrangler JL Driving on the beach, concerns. 1724333313961-wr
I bought one for $6 at Menards. You know save big money ant Menards. lol hahaha
morph860
NSB, FL
'24 JLURX 4xe, '24 GC 4xe
I drive on the beach almost every weekend. Never had to air-down my tires, but most of the sand here in the "traffic lanes" is pretty compacted. I usually just give everything a quick spray down with the power washer when I get home. If it gets wet, I do a full wash.
The sand that gets stuck in between the body of the Jeep and the fenders is the hardest to get out.
There are people who drive on winter road salt every day for months. One day on the beach isn’t going to hurt anything. Go enjoy it.
