Door Swap Tips
npj01
Nicholas
New Hampshire
JL Moab
Hi everyone!
I just got a pair of half doors for my Jeep. I was wondering if anyone had some tips/tools/recommendations that helps make it any quicker to swap the doors. Especially the t-50 bolts.
Thanks!
MOOG5050
Ny
Rubicon XR
Most 1/2 doors will drop into hinges and fit fine. No adjustment. Try installing and slowly closing for fit.
MOOG5050
Ny
Rubicon XR
Maybe I misunderstood, other than disconnecting the harnesses, you just remove retaining screw at bottom of each hinge pin, lift and replace with new door. And most of us never use the hinge pin retaining screw again. Lol
Aonar
N.W. Iowa
2012 Rubi and Snazzy 2021 JLURD
I swap mine only twice a year unless on a long trip and I need the security of the full doors/windows. Very easy but no shortcuts that I am aware of aside from not screwing in the hinge bolts. FWIW, I do use mine.
Jeep Wrangler JL Door Swap Tips 1688596230290
NJJeep Guy
New Hampshire
2020 Hella Yella JLU
Remember to lightly lube your door pins once a year as you switch them. Will help years from now
Xcoaste
Ben
PA
2021 JLUR - Past - '13 JKU, '97 TJ, '93 YJ
When using a ratchet to take the doors off, I put a large flat magnet, like the ones with your kids picture on it, on the Jeep so that I don’t scratch the paint. The JL is easier, but on the JK the ratchet would easily rub. Just a habit I got into take protect the paint.
thecritter
Rusty
East Texas
2018 Crystal Granite JlU Rubicon
Take the door hold opener off and push it into the door dont need it with the straps JL first Jeep to use them. Get a set of Door pins and take out bolts to never use again.
BDinTX
Dallas, Tx
I put tape on the head of the ratchet to protect the paint but that sounds like a good idea too.
Dan M.
Albany NY
2020 sport (2 door)
I have door pins to make it easier easier to align the door hings with the vehicle hinges (YOu don't need those T-50 bolts). Also, when I put my doors back on in the summer I don't hook up the electronics as my goal is to have the doors off as much as possible. Between not having to mess with the T-50 bolts and the wiring harness I can get both doors off in 5-10 minutes.
