Door stuck screw
SariK
Sari
Nazareth
Wrangler JL 2 doors soft top 2019
from my previous owner, one of the doors screws is stuck and I can’t remove it.
And when I try it keeps getting worse
What can I do to get it out? i got new screws to put in instead of that
Jeep Wrangler JL Door stuck screw A47B70BE-09E0-43DB-8927-F2D00F476915
kah.mun.rah
Merenkahre Jr.
Duat
If it is stripped you might be able to grab the edge with vice grips.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Once you break it loose, it shouldn't be too bad to get out. They normally spin on pretty easy then bottom out.
Concur with vice grips next. I'd throw some painters tape around the area in case you slip to protect the paint.
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Retired US Army, Higher Education
Great idea on the painter's tape. I know I'd for sure slip...Murphy sits on my right shoulder whenever I work in a vehicle (meaning I must sacrifice skin, blood, or paint during the session).
garykk
Gary
Southern NM
2022 JLURD
When you replace it, put a little never seize on the threads.
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
I wouldn't even put them back on. I've taken mine out on each Jeep I've owned and threw them in the trash.
same here... I know some people say that it would make it easier for some lowlife to steal the doors.. but I wonder who goes around trying to steal Jeep Wrangler doors ?
GATORB8
CLT NC
Hmm, Pain Train does have a sweet set of half doors that apparently aren't even bolted on....
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Lol.
There's no locks for the hood and it's tall enough to take whatever you want from underneath, too.
CaJLMetalHead
CAJLMetalHead
You could use the door itself as leverage.. protect the areas with either painter's tape.. or Gorilla Tape ... open the door... grab the bolt with the vise-grip plier, then close the door while holding the plier... in this case if the plier loses grip it will stay in your hand instead of flying, crushing your hand and damaging parts.. LOL
Maverick909
I.E.
hammer style hand impact tool. easy peazy lemon sqeezy
Apexcars
North Texas
2020 RAM 1500
You can also grind a couple of flats on opposite sides and use vice grips or crescent wrench if you can't get it with just vice grips. Generous use of penetrating oil and maybe even a heat gun can help if the bolt is stuck.
