Door hinge pin guides
Waynev01
Wayne
2020 jeep wrangler jl Sahara unlimited
I recently purchased new door bushings that came with door pin guides. I've read some people just leave them on year round some just during the summer and some only when reinstalling the doors.
As I am sure its probably a preference deal. What's the majority opinion ? Is it safe to keep these on year round ?
Joe's_Roxy
Arkansas
2018 JL Rubicon, 2009 JK Sport, 2006 LJ Sport
Quality Manager
Yes, you can leave them on all the time. Your doors won't "fall off" when closed and chances are will take a little effort to remove with the doors open...but, you will have to remove the detent rod in order to remove the door.
yokramer
Snark Incarnate
Ive had the guide pins on since about 3 months after I bought the Jeep and took the doors off for the first time with no issues.
Erievon
Al
Cleveland, OH
23 JTR, 21 JLU (Low) Altitude
I run them year round on the uppers only.
Same, but I put them on the bottom instead. For me this seemed to work better, once the bottom one was in the top I was able to line up easier.
Cutterone
NH
2025 Willys 4dr 2L Firecracker
I have run them year 'round one my last 3 Jeeps, the one before that I just left the bolts off. Just check them from time to time, I have had them loosen up so had to re-tighten them.
moabman-OG
Moab, UT
Jeep Wrangler JL Unlimited Rubicon
Mind sharing what you bought? I want a solution like this, myself.
etoften
Eric
Washington NC
2021 JLU Willys
Will it work? Yes. Is it safe? Maybe not. Kind of like putting a 22 long rifle bullet in place of an old glass fuse. Yep it works. One dead short away from losing a pinkie toe though. That sex bolt is the best thing keeping the door out of your lap if you get t-boned or roll over. Is the couple of minutes time saved worth it? Not knocking anyone that does it. I have a zinc allergy and eat oysters all the time. So roll the dice baby!
yokramer
Snark Incarnate
I dunno where the sex bolt is but if you get hit hard enough that the door breaks the hinge there having the nut on the bottom isnt gonna make a difference.
Maverick909
I.E.
I haven’t had the bolts back in my doors since I took them off seven years ago
TheRaven
Reading, Pennsylvania
Sold
yokramer
Snark Incarnate
TheRaven
Sold
