DOOR HINGE PAINT PROTECTION
Status
Not open for further replies.
Ezun
Chad
St. Louis area
Perfect. Took me a while on the first one, I think it looks pretty good. I’m going to move on to doing more of them now.... might take a bit of time.
Ok, knocked out some of them yesterday..... passenger side of the jeep done. I think I'll get the rest done this week.
ALEX-4LO
Alex
No where
2018 JLUR & 2020 JLUR - Project JL's
I ripped all mine out. After almost a year. I could no longer look at the door hinges with mud and dirt particles in the bubbles. The whole jeep looked white and door hinges looked like SH** , nah. Its ok if you do it perfect and have no bubbles or creases. But not worth it in the long run just get touch up paint.
Ezun
Chad
St. Louis area
Yep - to each his own.
Ezun
Chad
St. Louis area
@R 3 - Just finished installing my hinge protection and created an install video:
They look great. I can't imagine trying to cut the film to fit after seeing the cuts in these laser cut ones.
Install takes just under 15 minutes per hinge.
GeneralRizzo
Ryan
Hendersonville, NC
2018 JLU Sport S
Hey R3,
I ordered the JKU door sill guards. Tried install today and pretty sure the left rear driver is ruined. It may be salvageable. Put the rest on hold. Are the designed to protect the top of the door sills? I couldn’t get it to cooperate, nor could I find an install vid or much info online. The pinch seam was also problematic. Any advice?
GeneralRizzo
Ryan
Hendersonville, NC
2018 JLU Sport S
Hey R3,
Correction: JLU.
trailchaser
Javier
Haymarket, VA
2019 Moab
Thank you to every one for the positive reviews!
It is very true that patience is the key!
Thanks
Matt,
Hi Matt,
Installed mine last night in my garage, don’t think they came out as good..maybe it was too dark but I got some ugly spots, not that notica me but I know they are there...will they self cure or bubbles eventually dry out?
Thanks a lot, even if not installed perfectly I know I’m protected
Jeep Wrangler JL DOOR HINGE PAINT PROTECTION 954014DD-93D9-4199-94CE-C0C354F2E241
Jeep Wrangler JL DOOR HINGE PAINT PROTECTION CC9EBAF8-A75B-4963-B6DF-04F4FDC8A240
Jeep Wrangler JL DOOR HINGE PAINT PROTECTION 3AB5514E-FE5A-46A2-9806-84C58A362B51
Jeep Wrangler JL DOOR HINGE PAINT PROTECTION FDAF45B8-CF82-49A5-A736-3CCEA187FCF0
ashtonjarrett
Ashton
Santa Cruz Mountains
2020 JLUR
Engineer
Thanks for the install video @Ezun, how is it holding up a couple months in?
Ezun
Chad
St. Louis area
Thanks for the instal video @Ezun, how is it holding up a couple months in?
@ashtonjarrett they seem to be holding up well. I actually forget they’re there. I’ll have to look again tomorrow and see if anything stands out or looks wonky.
Ezun
Chad
St. Louis area
@ashtonjarrett I checked them this morning and they still look great. A few areas have clearly been hit by rocks, but the paint still looks great, and other than where they’ve had impact, they look perfect.
broox
Derek
Des Moines, IA
www.broox.com
2016 BMW M4, 2020 JL Rubicon
Software Engineer
Got the R3 door protectors installed on my 2-door over the weekend. It's a very slow/tedious process... not hard, it just takes time. So, have some patience, grab a couple beers, put on some good music, and prepare to spend some time chilling out with your Jeep.
If I were to do this again (or if I had a 4-door), I'd probably cut the larger hinge strips back so they just cover the barrel part of the hinge and not the entire thing. This would cut the time down considerably. R3 should really consider making a version of these that just cover the barrel. That's where the chips are most likely to occur anyway.
That said, the method and video that @Ezun posted was incredibly helpful. Check that out here...
And for the solution (which works incredibly well), that can be found here (note, i cut this recipe in half and still had plenty leftover after 4 hinges):
How to install 3M Paint Protection Film.
You can use an "All in One Solution" when you apply the 3M film.
You would mix and pour your solution into an empty, clean, spray bottle.
All in One Solution mixture:
8oz. of 70% Isopropyl Alcohol
24 oz. of Distilled Water (DISTILLED WATER)
2 ml of Johnson's Baby Shampoo
Upnarms
AZ
2019 JLUR, 2003 TJ X
And for the solution (which works incredibly well), that can be found here:
Agree, I've never got chips in any part of the hinge other than the barrel. Im just wondering if that thin film will actually stop chips from rocks flying back at 30+mph. I suppose it's better than nothing but seems a nice curved body color matched piece of plastic 3m'd to the leading edge would be ideal. Something a half inch wide or so.
OldGuyNewJeep
Don
CT
Mine have been installed since 6/2018 and they’re doing their job. No chips, and the film hasn’t budged.
Melny67
Melvin
Staten island
Jeep jlu
I have questions first one why do you have to cover the whole door hinge and not just the first front part of it? I thought rocks that get picked up by the front tires get shot out and catch the highest part of the hinge. Also will a front mud flap help? I had not seen many Wrangler with them but Mopar does have a nice set.
Barky
Beau
Scottsdale, AZ
JL Wrangler Rubicon
The JLU one for $40 I just want to confirm comes with 4 protection films (for all 4 door hinges)?
Status
