Does anyone actually like start-stop
Periokid
LI, NY
2018 Bright White JLUR and some others.
I am mixed. I like the fact that I am not burning gas sitting at a light. It would be more effective if the A/C did not rely on the engine because it causes the engine to start in the summer heat more often. Also, moving the brake pedal just a bit induces an engine re-start which is also annoying. Too many times I find the engine stop and almost immediately re-start in traffic.
Sean L
Sean
North Carolina
I think with heavy stop and go traffic (Highway lane closure, Etc.) its best to just hit the disable button. Pretty much any other time I let it operate.
kculp
KEN
Iowa
2018 Sahara JLU
Professor in the health sciences
When I pull into a parking spot (or garage) ESS shuts the engine off, then with foot on brake I put it in park and the engine starts, then I hit the Off button to shut it off. So I get: park car, shut OFF, restart, then shut OFF. Horrible.
The dealer told me the USgov requires ESS but this is a poor implimentation of it.
Same problem here. If when I park and think about it: pull in slower, don't press hard on the brake. How often ... not very... Sometimes it does it and sometimes not. They should program it never to start in park unless the ignition button is pushed. Generally I am tolerant of ESS and try to not think about it so much, but this parking thing you describe is really annoying.
Sean L
Sean
North Carolina
Best way to deal with that is to pop the transmission into neutral as you are stopping, then put into park as you are fully stopped. it avoids the unnecessary ESS shutdown and restart.
obwahn
Inland Empire
www.youtube.com
Retired puter dork
Mine is behaving quite well with the light touch on the brake. I'm stopped, not moving, and the engine is still running. Sometimes it even takes a bit of pressure to get it to stop the engine, I like that.
smithrd65
San Antonio
2018 Jeep Wrangler Rubicon Unlimited JL. BMW Z4 35is, Tesla Model X90D, Chevy 2500 LTZ
I don't have an issue with ESS I have owned several vehicles with it and never Had an issue.
Actually I think it's cool.
emoody007
Eric
Rockwall, TX
2018 JL Rubicon 2.0 Turbo
Or press the disable button just before or as your pulling into a parking spot.
xeon
JLU Rubicon
ESS / Auto Start Stop. it was a feature I was dreading. It was a feature that annoyed the hell out of me in the beginning. So of course i chose to shut if off using the button. Then after a few long trips and 14 and 15 mpg. I thought I would test it out and see if it would help out. Sure enough it did. Those 14 and 15 mpg trips quickly moved to 16.5 and 17.5 mpg trips. Now, I am disappointed when it doesn't engage. Little did I know that if you have Auto Climate Control on it disables the ESS. So now i try never to use Auto Climate and the ESS engages more frequently. Yay.....even better high way milage.....getting about 18.5 to 20 on long trips. So...ya....happy with it :)
Sean L
Sean
North Carolina
What do you have your Temp set for on auto climate control? Must be frigid because I keep mine on 75 and ESS works just fine once the Cabin has cooled down.
xeon
JLU Rubicon
Most times set to 68. If AC temp setting is 20 degreed cooler than the outside temp the ESS will be disabled. This is a condition of almost Max AC but not quite as the recirculation vent is not closed. Most days out here in So Cal this summer have been well over 95F so even it I had it set to 75F it produces the same effect. Who knows.. maybe...its a problem with my system and it could be.
Sean L
Sean
North Carolina
ah, Is that temp difference actually programmed in to the ESS that you know of? Its been mid 90s here as well this past summer and I haven't has any real issues with it operating once the A/C cooled the cabin down.
xeon
JLU Rubicon
I think you might be right once the cabin temperature cools down. I run a soft top so its like having a plastic bag over your head on hot days. I will be switching back to hard top in a few weeks and I will see if its any better. With respect to the temperature of 20 degrees. its not a programming thing but a recovery temperature most automobile AC units can't over come to easily. Now I must say the JEEPs AC is quite good so the variance might be a bit wider. I don't have any technical resource that says Jeeps is 20 degrees just from cumulative experience of working on AC units over the past several years.
emoody007
Eric
Rockwall, TX
If it's my guess, I don't think it would be a specific temperature. The auto temp is designed for you to set the temperature to what you want it to be then the A/C or Heat blows colder or warmer in an attempt to hit that temperature. So somewhere there is a thermostat reading the cabin temperature and adjusting the AC or Heat to meet the temperature you have it set for. If you have the temp set at 72 and the cabin is 82 then the AC will be working really hard to reach that temp thus disabling the ESS to help reach or maintain temp. Im not sure what the variable would be for the auto temp to kick on the AC or Heat but it would be much like a home thermostat. I'm just guessing so if someone knows for sure, please correct me.
