Dodging bullets, but finally got hit
Headbarcode
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
If the IPC is indeed f'ed, my next question is whether or not I can swap it out myself. Is the dealer required for anything beyond transferring the odometer reading over?
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
does the speedometer / tachometer work while you drive?
I also have the AlldataDIY subscription... it is a great tool!... forget about getting the USB MOPAR Authority service manual... expensive, super hard to use, and it is missing info...
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
The instructions don't say much about the programming side of things. The best I found was actually a 4xe recall, and it seems to skip the reprogramming part.
@roaniecowpony 's link seems to indicate that there may be some more hurdles.
I'm going to PM you the recall instructions since I can't find it online. There are two procedures, the first is the update one, then on page 5 it actually goes through the remove and replace procedure. Remember, this was for the 4xe, so there's some "high voltage" steps thrown in that may not apply.
fczabala
FL
JLUR; X5
I'm on LI as well if you want/need to scan it I have the Jscan app and the obd2 adapter and alldata subscription
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
GATORB8
CLT NC
Crazy another thread popped up
For real.
What he’s saying about the auto roll forward seems to make sense with the Recall procedure. It basically says to save the original odometer in Witech, then just plug the new one in and pull the negative.
Headbarcode
Headbarcode
LI, New York
Yes, the speedo and tach work perfectly normal. So do the warning and indicator lights within them. It's just the lcd screen related stuff that's not being nice to me.
Headbarcode
Headbarcode
LI, New York
First, the flu was going around. Now, it's seems we are in IPC season. ?
I'm just remembering a recent hiccup with my dash screen. I got a nasty wobble several weeks ago, which has been addressed, and immediately noticed a sporadic flickering in the dash screen. It lasted the rest of an hour long drive, but went back to normal the next morning and has been fine until this whole thing happened. I wonder if something got shook loose, or maybe damaged, and finally bit the dust.
bumpit
2022 Grand Cherokee 2019 JL Rubicon 2018 370z
whats a new unit cost to put in? Hopefully it doesn't come to that but I know some of those guage cluster can be crazy expensive.
roaniecowpony
Retired Engineer
I looked up my JLUR cluster online. Something short of $700 IIRC. But you can add another 20% if the dealer sells it to you.
roaniecowpony
Retired Engineer
These guys have a nice video on R&R of the cluster. I think it may be worth your time to just pull it out and check the connector on the back. Daytona Edition Custom Gauge Face for 2018-2022 Jeep Wrangler JL and Jeep Gladiator - WRA18JL - US Speedo - Everything Speedometer
