DIY tailgate table kickstand ideas needed
LKG
Larry
Boise, ID
23 JLUR Manual, Gen 2 Cummins, 22 Sport Altitude Manual R.I.P
I could use some ideas for a kickstand for my tailgate table. I wasn't a fan of the table height with the hinge at the bottom so I built my own. I popped out the trail rail cover and mounted a block of wood to the existing trail rail mounting holes and voila. This raised the table from around 33" +/- to 45" which is a whole lot more comfortable IMO. The wood kickstand works but it looks a little Jerry Riggy and it's bugging me. I would love some ideas to clean that up and make it look a little more professional.
Jeep Wrangler JL DIY tailgate table kickstand ideas needed PXL_20230301_004617189
Jeep Wrangler JL DIY tailgate table kickstand ideas needed PXL_20230301_004548683
Jeep Wrangler JL DIY tailgate table kickstand ideas needed PXL_20230301_004609677
Opus
Midwest US
www.jlwranglerforums.com
I think as far as design goes what you have is about your best and cleanest option for a higher and larger table. The only thing I would worry about is that you are putting a lot of stress on one point at the end of that brace where it meets the plastic on the tailgate. Consider maybe distributing that point load over two braces?
Fudster
Elliot
Athens, GA
2019 Sahara
Hi Larry:
Stolen right from the pages of some woodworking magazine, imagine that the bottom view of your table looked more like this:
Jeep Wrangler JL DIY tailgate table kickstand ideas needed 1677952023814
Imagine there is a piece of wood running the width of the table (that is the width when it is not extended/telescoped to its full working width) about 1" deep, permanently attached to the tailgate.
Connected to this piece are your hinges, attached to your table.
This lip I envision might allow, on its underside, to contain two support arms that tuck under the lip when the table is not in use, but flip out to provide the under support your 45 degree member is doing above. One support arm that comes out to 45 degrees might also be possible.
More hardware options https://tinyurl.com/3zeb4ejm present themselves if you are willing to put a vertical wood board on top of the interior grill of the door, to which such hardware can attach.
LKG
LKG
Larry
Boise, ID
True, although it's actually pretty solid as it sits. If I can't figure something else out I plan on widdling/customizing the kickstand a bit so it's less likely to pop off the plastic panel. I 'll definitely make two.
LKG
LKG
Larry
Boise, ID
Hi Larry:
Sorry, I'm not sure I follow.
RubiBlueJLU
Missouri
2021 JLUR Diesel
Structural Technician
A simple idea:
2 triangular-shaped legs, one at each end, hinged off of the bottom of the table.
Fold down and rest against the tail gate plastic. Strong support for the table.
They would fold up under the table, towards each other, when not in use.
Might have to modify your table hinge to make room for the new legs.
Jeep Wrangler JL DIY tailgate table kickstand ideas needed 1677956813066
LKG
LKG
Larry
Boise, ID
MPTee
Pacific North Wet
Jeep - "nuff said
Exactly what Rubi said. Here’s mine out of aluminum.
I like the high table too, but can also drop the base for a lower shelf if needed. Very handy and easy to deploy or close.
Jeep Wrangler JL DIY tailgate table kickstand ideas needed 222F685E-603D-49A3-BF71-CCC3F73CCE73
Jeep Wrangler JL DIY tailgate table kickstand ideas needed B698A509-305F-4FB7-A689-A17F9880AB34
Jeep Wrangler JL DIY tailgate table kickstand ideas needed 226EAD58-5943-4BC5-B6FC-6CBB7D5411C7
Jeep Wrangler JL DIY tailgate table kickstand ideas needed E7A8D305-B898-4B92-8675-0C3D24C04A82
LKG
LKG
Larry
Boise, ID
A simple idea:
I like that a lot, I only have enough "meat" for a hinge/triangle on the left side but I proped my kickstand up on the far left and if felt plenty sturdy. I'll have to add a bumper/contact point to the plastic panel but that'll clean it all up nicely. Thanks for the idea.
LKG
LKG
Larry
Boise, ID
I like your's even better damnit, if I wasn't such a cheap bastard I'd just order one, haha.
MPTee
Pacific North Wet
Jeep - "nuff said
Thanks - mine is home brew too. Cost virtually nothing (from scrap parts in the bin), but it did take a few hours of figurin' to make it work.
I like your wood one - simple and effective.
ArcadeTracks
PJ
Pittsburgh, PA, USA
It looks great to me! To get the look you want, maybe paint the kickstand with black Plasti-Dip or a metallic rattle can?
LKG
LKG
Larry
Boise, ID
Yup, about 3 bucks in hardware 1/8" cover sheets and a few pieces of wood/plywood liberated from the scrap pile as well. The Baltic Birch ply is becoming scarce thanks to Russia and Ukraine.
