Disconnecting Security Gateway Module 2021 Rubicon
Barney392
High Desert So Cal / Lake Havasu, AZ
Ok thank you.. I haven't had that 2nd cup of coffee yet so my apologies for my dumbness.. I get it now.. Geez.. Thank You again..
Here's a picture of my Jeep looking below the dash panels. The connectors at the bottom with all black wires are now connected to the SGW. The connectors on top with all the different colors are the connectors that were originally connected to the SGW. This way you can easily get to them without all the hassle.
Jeep Wrangler JL Disconnecting Security Gateway Module 2021 Rubicon SGW Extension Cables
Terpsmandan
Penn Yan
Another idea is the SGW extension cable from Z Automotive:
https://www.zautomotive.com/product/z_sgw_ext/
I have one for my Tazer and it just extends the SGW plugs. When I did the stereo, I forgot to move the SGW to the new speaker pod and the SGW now sits in my console with my Tazer connected to the sgw line.
Gmanjeeper
Arkansas
2022 JLR
Finally! I successfully removed the two cable plugs from the security gateway in my JLR. After several hours and many trips back and forth, I figured this out. Basically with my left hand I held a long, thin screwdriver blade on the push tab and with my right hand I wiggled and pulled on the cable. It was a bit nerve wracking - I did not want to damage anything with the screw driver blade and I certainly did not want to pull any of the wires out of the connector. Wiggling with firm pulls on the cable eventually got it! Now I need to figure out how to connect the Z automotive extension cable back up in the security gateway!
Gmanjeeper
Arkansas
2022 JLR
Yup, the best method is the long flat blade screwdriver to push the tab for each connector one at a time. Then just shove in the Z cable and never remove the cable. The 392 is slightly easier due to the swg moving a bit.
Did you tug on the cables or were you able to get your fingers up onto the plastic connectors to pull directly on the connectors. I have heard one guy pulled one of the wires out. I really did not know what I was doing and really the only thing I could get any leverage on were the cables. I have a friend who, now that I have mine out wants me to help him and I do not want to damage his wiring. If the wiring is damaged I am not sure what the fix would be.
Gmanjeeper
Arkansas
2022 JLR
I just pull on the cables. When you release the lock with the screwdriver there is very little resistance. If in doubt find another oem connector and practice on it. The screwdriver blade width maters.
Ok, I need a bit of a refresher. I successfully pulled the OEM security cables and installed the Z Automotive extension in the OEM security ports. As I recall, I plugged the other ends of the Z Automotive extension into my ECRI bypass module and then made a few changes using my OBD Bluetooth scanner and JSCAN app. I had to have some work done at the dealer and so I disconnected the ECRI module from the Z extension and then plugged the OEM security cables into the Z extension (where the ECRI module had been). I now want to plug the ECRI module back into the Z extension so I can make a few more changes via JSCAN. Two questions. To disconnect the OEM security cables from the Z extension, do I just pull on them or is there a lever of some sort that I need to squeeze or press first? (I have taken a quick upside down look and do not see anything to squeeze or press). Second, once I get these cables disconnected and the ECRI module plugged back in, do I just leave the OEM security cables dangling (at least until I go back to the dealer)?
Thanks.
Ormond Beach, Florida
Retired at 55 ..
Thanks.
https://www.jlwranglerforums.com/fo...teway-extension-cable-use-explained-➿.111159/
Retired at 55 ..
Thanks.
https://www.jlwranglerforums.com/forum/threads/tazer-mini-install.79683/post-1665568
Gmanjeeper
Arkansas
2022 JLR
Retired at 55 ..
phi502
Nick
TN
21 JT Rubicon
Agree with the suggestion for the harness extension. I bought these on Amazon and they have worked great... you actually get 2 sets for the price
https://amzn.to/3raQgJS
Retired at 55 ..
I have seen them. Bulky, Crappy. Would not use if you gave them to me for free..
