Diesel Skids questions before ordering
SparkleTooth
Earth
Stellantis SUCKS
I want to finish this build and am need of skids. I have it narrowed down to the Metalcloak option or Rock Hard. With Black friday I can save a little on the MetalCloak system, but didn't necessarily want to go with Steel, so I am leaning towards Rock Hard, but obviously that means spending an additional 700-800 bucks.
First, I can't seem to get a good shot of either system in regards to the Fuel Filter. I can't tell if either system allows access to the Fuel Filter, can anyone confirm.
Secondly what is the consensus for how dealers handle repairs with jeeps with full skids. It was never an issue with my 4 Runner, but Jeep service is abysmal at best, and I fully expect them to complain about removing skids if they ever need to make a warranty repair underneath.
Would love to hear your thoughts on either the Rock Hard or Metal Cloak. Full disclosure I do have the MetalCloak 3.5 GC
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
No experience with Rock hard.
But I have the Metalcloak. There is a removable panel that gives you good access to the fuel filter. I've done one change so far and it's easy. They have you remove the wimpy stock skid during installation so it's just 4 bolts to remove the panel and the filter is right there.
As far as dealer maintenance, I don't trust them so I never have them work on it unless it's warranty work. So no advice there.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Oh, and if you're going to do your own filter change do yourself a favor. Get a 28mm socket. They're not terribly expensive on Amazon.
rickinAZ
Phoenix
2026 MOAB 392
Roy, I always keep notes for DIY jobs that list stuff like tools required. It helps me the next time I perform the same job. My notes say 27mm. Which is correct?
DwnSth
SE Louisiana
2002 TJ : 2021 JLURD : 2013 F150 : 2025 Bronco
I think they all have access to the fuel filter. I have Nextventure (excellent with the UHM and not much weight gain) and it's an easy to remove panel. No experience yet with the service end of things but will find out in a few weeks. I suspect I'll be charged something for the labor to remove and replace the cover (although I may remove it before I bring it in.).
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
27mm is the oil filter I believe. The fuel filter is 28mm because why should it be easy? I discovered that little fact the first time I did the fuel filter change. I managed it with a 1-1/8" socket but it was a little sloppy. Fortunately, it's the same torque as the oil filter (18.5 ft-lbs) so I didn't break anything.
rickinAZ
Phoenix
2026 MOAB 392
My bad. You’re right, it’s the oil filter I was thinking of. ?
DEZELJP
Paul
Washington
2020 JLURD, 2014 Grand Cherokee Overland Diesel
as @grimmjeeper said: Drop this door on Metalcloak the wimpy stuff is gone. Pull the door before you take it in, that part would be a simple job with no mess.
Jeep Wrangler JL Diesel Skids questions before ordering 80D3BAF0-8BC0-4405-8920-CE368102F7A0
Artec
North Salt Lake, Utah
www.Artecindustries.com
2014 JKU, 2020 JLUR 2019 JTR 2021 JTRD
Have you considered the Artec Diesel bellypan ? Ours is made from 1/4" 6061 aluminum with 3/16 Zinc plated steel bracketry an has Stainless counter sunk hardware so no rust to worry about . Transitions between panels are very tight and virtually seamless so nothing to hang up on. It has a panel to remove to access the fuel filter and water separator. Once you remove the oem skids our kit will only gain about 50lbs total weight on the diesel while adding way more coverage . It's on sale for 15% off with free shipping currently
https://artecindustries.com/product...l-diesel-aluminum?_pos=3&_sid=3b7918136&_ss=r
Jeep Wrangler JL Diesel Skids questions before ordering 1669153250466
Jeep Wrangler JL Diesel Skids questions before ordering 1669153281338
Jeep Wrangler JL Diesel Skids questions before ordering 1669153661726
Jeep Wrangler JL Diesel Skids questions before ordering 1669153695275
Jeep Wrangler JL Diesel Skids questions before ordering 1669153740398
Jeep Wrangler JL Diesel Skids questions before ordering 1669153763795
Jeep Wrangler JL Diesel Skids questions before ordering 1669153307796
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Slick looking skid plates. Does that 50 pounds include the DEF skid?
Artec
Ratbert
PNW
Software Engineer
Artec
SparkleTooth
SparkleTooth
Earth
Stellantis SUCKS
I did consider Artec, that is until I saw the price when combined with the DEF skid, although I think I prefer it to MetalCloaks offering. Plus it is currently on Backorder from the looks of it.
