Dented Oil Pan
tehfrr
WA
2023 Jeep Wrangler Rubicon 4XE 20th
If your oil pan looked like this, what would be the urgency on replacing it? ASAP? Not immediate but soon? When it’s convenient? Don’t bother?
Jeep Wrangler JL Dented Oil Pan IMG_0401
tehfrr
tehfrr
WA
I would do it ASAP but, that's me. And install a skid plate at the same time.
Yeah, I really want to install a steel belly pan only reason I haven’t already is because Jeep can’t seem to fix a transmission leak. About to go back in for the leak a third time.
garykk
Gary
Southern NM
2022 JLURD
Unless it bothers you looking at and no leaks, I’d leave it.
I would use a rattle can to touch up the scrapes though.
CopperMtnGuy
Ross
Wisconsin
2018 JL Wrangler, 2005 KJ
Looks like a pretty hard hit! Decently tricky the hit the oil pan, doesn't seem common. I'd replace it at your leisure but would replace it.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I'd do it before you bring it in to them again (unless you're gonna pay the dealer to do it anyway).
I'm not finding the lower pan separate from the oil pan assembly, although it looks like it may be available from the diagram.
GATORB8
CLT NC
Deleted Member RoadNomad
Guest
If your not having oil pressure issues or strange rattles from below and there are no leaks its probably only cosmetic.
If its under warranty replace it before you go in for a service problem. Then change it when you perform your next oil change and at the same time invest in a skid plate while your under there.
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
I would not spend money on a new pan... but rather a skid.. whatever you were doing when you crushed that pan is going to happen again.. and perhaps you are not going to be that lucky next time, especially without a skid.
stumblinhorse
Not familiar with the 2.0 motor enough to know where the oil pickup is, so only comment is as @RoadNomad mentions if you have a different oil pressure, then you have a problem. Or maybe a potential problem as sludge builds it might block.
mgroeger
Southern UT
2021 JLUR 2.0T
Don't bother. I drove around for years with one dented worse than that. No leaky no fixy
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
tehfrr
tehfrr
WA
Thanks everyone. I think I should got a bellypan as my next upgrade.
This is not my first undercarriage damage, and as ppl have said, it will not be my last.
