D44 rear Diff cover
MntGoat
Doug
TN
2022 Rubicon
Machinist
Will "normal" D44 diff covers fit the 22 jl rear and/or front axle housing?
I have made several in the past and was going to reuse them if they cleared steering and track bars on the jl
Tia
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Nope. JLs have the new Advantek line from Dana.
JK:
Jeep Wrangler JL D44 rear Diff cover 1752174805960-ex
JL:
M210 Front:
Jeep Wrangler JL D44 rear Diff cover 1752174775902-i1
M220 Rear:
Jeep Wrangler JL D44 rear Diff cover 1752174826370-mt
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Tia
The rear axles changed for the JL starting in 2018.
While the marketing department calls them by the old names, Dana 35 and Dana 44, they really are the Avantek M200 and M220. They share basically zero common parts between them.
Same thing applies to the front "Dana 30 and Dana 44" being the M186 and M210.
I was thinking maybe the cover bolts....but the Advantek is metric. Not sure when Dana went metric...
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
Okay, cool.
Great info!!! after looking at the front D44 and the ridiculous amount of leverage against the upper C i shook my head...WTF???
So I guess I will sell the covers I made and make some more for these.
Need to find takeoffs to measure
Thanks!!!
GATORB8
CLT NC
Okay, cool.
Thanks!!!
I know you're a machinist and probably want to do it yourself, but Barnes down in Mills River has some cool stuff and may give you some inspiration:
https://barnes4wd.com/
GATORB8
CLT NC
I've asked before and never got a straight answer. Which fill hole do you use?
Good question.
Upper is initial fill, lower is service fill, this is from the UD axle rebuild specs:
Jeep Wrangler JL D44 rear Diff cover 1752242838202-xs
jellis4148
Missouri
Seems like that would be a huge loss of fluid if the bottom one is used for service fill. If you fill it to the top one, and in 6 months use the bottom to check and nothing comes out. That, to me, seems like a huge loss of fluid.
GATORB8
CLT NC
I'd assume the service fill is the design capacity, and the initial fill is for extra lube to carry break in wear metals or to ensure lubrication of bearings/seals.
jellis4148
Missouri
So if I change my diff cover to that one, do I use the top one for the initial fill, or the bottom since my diff has miles on it?
GATORB8
CLT NC
I'd use the bottom.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I open both. I put oil in through the top hole. I fill until it comes out the bottom.
When filling, I use a pump with a hose that is stuck in a bit. That way I can check the level through the bottom hole as I go without having to pull the hose.
jellis4148
Missouri
Seems awfully confusing. Really don't see the point in two different levels. Just asking for and idiot like me to overfill it, or under.
