RickyPal
Ricky
Orange County
24 JLU Rubicon XR
@Roky what is the secret to get your 19.5” compressed length rears to that much bump height? I have billsteins with the same length right now and this is them at full stuff. I had to add 2” of bump stop to not bottom out. These are 38” Nittos. I still have 2” of clearance all around and I didn’t even have to trim the seam cause of the bump.
Jeep Wrangler JL Crystal Rubi build… 7CA6D2FD-040C-4893-82D1-E226B5D4BB1C
Roky
Roky
Roky
What’s your setup ? And how are you flexing it ?
RickyPal
Ricky
Orange County
24 JLU Rubicon XR
In the rear is a 3.5” metal cloak spring with billstein 5100s with the following specs:
Collapsed length: 19.49 inches
Extended length: 31.68 inches
To flex I removed the springs and went to full bump on one side. I added two inches of bump via metal cloak blocks (removed the 1” stock XR bump).
I had to add 2” to prevent bottoming out the shock. Had about 0.25 of shaft left
Axle is centered with an adjustable core 4x4 track bar, metal cloak sway bar links with their spacer block to prevent hitting frame.
Roky
Roky
Roky
What about control arms, adjustable or stock?
Roky
Roky
Roky
What I’m most curious about is did you move shock brackets at all? Or are you thinking I may see a different story when I’m flexed on the trail?
Yes I’m running a Rock Krawler long arm kit, with a 3 link in the rear….. The rear shock bracket gets raised 3 ish inches, and the upper bracket also gets raised, so it still the same distance apart but raised up 3-3.5”…. The 3 link rear, really frees up the rear axle, and the long arms let the axle stuff and droop straighter, doesn’t get pulled/pushed fore and aft……
Roky
Roky
Roky
Flexed out the new shock brackets and, I could swear I heard the shocks say “thank you” … ?
If I’m honest, can’t feel any difference but doesn’t mean there isn’t one….but the way they look flexed makes me feel like there’s a difference…….Also, I was wondering how my brake line brackets were going to work out, but they actually are in a better orientation, win, win…:like:
Jeep Wrangler JL Crystal Rubi build… IMG_0005
Jeep Wrangler JL Crystal Rubi build… IMG_0004
Jeep Wrangler JL Crystal Rubi build… IMG_0007
hoag4147
Colleyville, TX
2022 JLUR XR
Even before your long arm swap I thought you were getting more stuff then pic above running long travel shocks?
Roky
Roky
Roky
Good eye Rick….I’ve been a bit lazy with my rig lately…? ….
Jeep Wrangler JL Crystal Rubi build… IMG_9009
…… when I put the MC jounce bumps in, they’re a little longer than oem, and I never got around to taking the half inch puck back out……?.
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Outboard for the win, Roky!!
RickyPal
Ricky
Orange County
24 JLU Rubicon XR
Do you happen to have a picture of your wheel stuffed when you were pre - bracket?
either way that answers my question though. With those specs you’d have to move the bottom and top mount upwards in order to stuff more than my picture, I believe (stuff as in tire in we’ll not bump to jounce). Thank you very much for sharing the info and setup. I think to stuff more and get as much droop as I currently have, I’d need to do the MC brackets and get the 6 pack shock. I’m not seeing any ~31.5” length extended shock that’s under ~19” compressed and I’d like ~17 compressed
Roky
Roky
Roky
Sure….. here’s a couple……. I get asked on occasion why so much fender gap ?
Jeep Wrangler JL Crystal Rubi build… IMG_9898
Because I need it, ?
Jeep Wrangler JL Crystal Rubi build… IMG_9290
Jeep Wrangler JL Crystal Rubi build… IMG_0011
RickyPal
Ricky
Orange County
24 JLU Rubicon XR
Great shots. I’ll see how mine articulates in the wild this Saturday. P.s just noticed we’re running the exact same sliders and front bumper
