Cowl Mounts For Baja Design Lights
Tdkrum5
Ted
WA/AZ
20 White JLU Altitude
Post pictures and let us know what you think about them. I was worried that with only two mounting bolts they my rattle or vibrate a lot? Let us know how it all works out? Love the BD lights.
CarbonSteel
CarbonSteel
They have plastic stand-offs with hex bolts and I will apply a bit of blue thread locker to them for security. The mounting plates are 1/8" thick so they should not flex very much if at all. Will keep you posted.
Jeep Wrangler JL Cowl Mounts For Baja Design Lights dCjBDl
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
Hands down Kc mounts. Way better than the BD ones. I cannot speak to any others as I have not had them in my hands.
Jeep Wrangler JL Cowl Mounts For Baja Design Lights 7A892F6B-D037-4110-8A33-B92597009563
CarbonSteel
CarbonSteel
Curious as to what makes them better than BD. They appear to mount to the windshield hinge?
Tdkrum5
Ted
WA/AZ
Thanks keep us posted i would only be mounting one of the small pro ditch light similar to yours.
Tdkrum5
Ted
WA/AZ
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
windshield hinge and they are made of thicker steel. No vibration.
CarbonSteel
CarbonSteel
How thick are they (could not see any specs on the KC site)?
CarbonSteel
CarbonSteel
Bout this thick....... 1/4” or so....
Between the rain, I mocked up the driver's side. I can move the entire Jeep from the mount, so it is solid and doubtful it would vibrate since the distance from the mounting hole to the centerline of the cowl bolts is pretty short and the plate is a little thicker than 1/8",
The only thing I am not sure that I like is the Baja's have multiple holes in the light bracket base, but only a single hole in the cowl mount. It is a 3/8" bolt so I can tighten it quite a bit and it has a nylock nut, so it may not be an issue. I would need to go ahead and mount them and drive it to see how it is.
Jeep Wrangler JL Cowl Mounts For Baja Design Lights dok8N
Jeep Wrangler JL Cowl Mounts For Baja Design Lights dokSDu
Jeep Wrangler JL Cowl Mounts For Baja Design Lights dokvR9
Tdkrum5
Ted
WA/AZ
They look pretty sweet to me.
Beetle Bailey
SoCal - Orange County
2019 JLUR, HD Dyna, HD Softail
Thanks just checked them out is there a spacer between the bracket and the body? Looks like these just sit on the body and dust and dirt may under them and cause the paint to rub off and rust? Has this been a problem?
Yes, the spacers sit in the opening where the stock screws are. Hauk furnishes the spacers and longer screws. No issues at all.
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
Tdkrum5
Ted
WA/AZ
