Cowl Mounts For Baja Design Lights
CarbonSteel
CarbonSteel
This is why I went with the KC. Two point mount, but very solid.
Yep--you were totally correct; looking at those now. The Baja's have a fairly wide base plate, can you tell me how wide the KC mounts area is?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
Let me know if this helps.
Jeep Wrangler JL Cowl Mounts For Baja Design Lights FD0E6B06-240D-4113-B2DD-473895ED012C
Jeep Wrangler JL Cowl Mounts For Baja Design Lights 2C225657-9E27-43F5-9A45-A9DF14D572C9
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
How far from the center of the light mounting holes to the outer edge?
It is slotted. Center of slotted light mount is about 1.5” from end (outside of mount)
Jeep Wrangler JL Cowl Mounts For Baja Design Lights B925A848-B2FD-4489-8B8E-57BFB1A5E899
CarbonSteel
CarbonSteel
Closer to 3.5” from the pic above. On the upper mounting platform.
Should work well on the XL Sports. I know you have to replace the cowl bolt with a new one, but what about the hinge bolt? Is the OEM long enough or is there a new one with the mount?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
Windshield uses the OEM, it is a strange sleeved bolt.
CarbonSteel
CarbonSteel
I finished roughing in the wiring and mounted the lights today. Many thanks to @Gdub for his advice on the KC mounts; they are VERY nice--rock solid and were cheaper than the Baja's.
I am having a new relay mounting plate machined so I will wait until I receive it to complete the terminations, but here are a few photos:
Jeep Wrangler JL Cowl Mounts For Baja Design Lights d7tX94
Jeep Wrangler JL Cowl Mounts For Baja Design Lights d7tVSf
Jeep Wrangler JL Cowl Mounts For Baja Design Lights d7tjN2
Jeep Wrangler JL Cowl Mounts For Baja Design Lights d7trHx
Jeep Wrangler JL Cowl Mounts For Baja Design Lights d7tSc
Jeep Wrangler JL Cowl Mounts For Baja Design Lights d7twtS
Jeep Wrangler JL Cowl Mounts For Baja Design Lights d7tkPe
Jeep Wrangler JL Cowl Mounts For Baja Design Lights d7tOo7
jimim
NEPA
2020 Rubicon, 2017 Tahoe LTZ
Guys from watching this thread I ended up going with dual lights on each side. I used Baja squads. I got a question. For the lights on opposite side of the Jeep should I just run under the wipers so I’m behind the firewall? And then meet up with the other 2 lights to go down to the aux switch tie ins?
I ended up ordering the dual mounts from Baja. They looked pretty low profile.
this thread helped a lot even though I kinda went off in a somewhat different path but I wanted to get everything from one place.
I’m still trying to learn here.
CarbonSteel
CarbonSteel
Just tuck it under the cowl, no need to run it all the way under the windshield wipers unless under the cowl is what you meant.
See below:
Jeep Wrangler JL Cowl Mounts For Baja Design Lights dYIf1
Jeep Wrangler JL Cowl Mounts For Baja Design Lights dYIqru
jimim
NEPA
See below:
Oh so I can have it in the engine bay but tucked under? I thought I had to be behind the foam stuff.
jimim
NEPA
Ahhhh I got to get covers for my lights! I totally forgot.
