Cowl Mounts For Baja Design Lights
CarbonSteel
2023 Ford Bronco Wildtrak
Gang,
What mounts are you gals and guys using to mount 3.5" to 4" LED lights to the cowl?
cosine
NY
2019 Wrangler Sport jl
Gone Postal
i picked up the rough country kit which includes 2" led lights and low profile mount. i love the low clean and simple mount. the 2" led fits nicely and "tight". i would double check if your light will fit and clear the windsheild. zroadz have similar one too.
Sentinel
Jason
Gastonia, NC
Baja Designs sells their own kit with the A pillar cowl mount and lights.
CarbonSteel
CarbonSteel
Thanks for that; I finally found it after a bit of a search, but I think I like the Mopar mount a little better then the BD one...decisions...decisions. ;)
72Blazer
The Real South Texas
72BlazerCrawler 72Blazer12V 88SBDuramax 18JLUR
SLP
Just ordered the Artec dual light mounts. We will see how they look when I get them. I considered the RC 2” kit but looked too small for my needs. Good price tho.
Hayseed_JLUR
Midwest
2019 JLUR, 2015 JKU
The KC ones are minimalistic and install easy. Hold my 6" slimlites rigid.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
This is by far my favorite a-pillar light mount out there right now. Only reason I don't have it is because it was designed for rigid industries ds series cube lights. Great, high quality lights but I'm wanting to stick with Baja Designs for all exterior lighting. What makes rigid cubes different from the rest is their inset hidden mounting points vs the outer edge mounting points of Baja and others. If only artec would release a version that accommodates a wider mounting dimension.
72Blazer
SLP
holy crap. I did not know that. Well damn. I was planning to mount some Traveller cube lights from TSC. Guess I’m going to have to do some modifying.
Headbarcode
LI, New York
Found this random shot of another rigid light that fits inside the bracket ears. So more than the ds series fits. You should search some light options that fit that narrower space
Jeep Wrangler JL Cowl Mounts For Baja Design Lights jjdhgshux_resized
72Blazer
SLP
Thanks. I’m wondering if the 4” pods would fit on there as that was my original plan. Once I get the mounts this week I’ll do some test fitting.
Headbarcode
LI, New York
I would've gone with the rigid side shooters on these mounts, to also gets some peripheral illumination
CarbonSteel
CarbonSteel
So I ended up buying the @BajaDesigns single cowl mounts and their XL-R Sport High Speed Spot Lights. I recently dumped XFinity as my ISP and went to AT&T Fiber. AT&T "paid" me $400 in Visa gift cards to switch and I used them to fund this endeavor. This will complete my light upgrades and so I am good for now. If/when the cheap cube reverse lights I installed fail, I may look at BD or Rigid for replacements.
Tdkrum5
Ted
WA/AZ
20 White JLU Altitude
Thinking of the single cowl mount bracket also. Post some pictures and let us know what you think?
CarbonSteel
CarbonSteel
The lights arrive next week and will definitely post photos after the install.
CarbonSteel
CarbonSteel
Here are the mounts and the lights (lights came in a bit ago). Now, to build the wiring harness and mount.
