Correction FCA did their job!
Sahara4xeland
Andy
Miami
JL Willys Sport XR.
Hey peeps!
What is the correct procedure to start a claim with FCA....
I have a XR willys which was supposed to be shipped with Anti-spin LSD as per my build sheet and it was NOT. I have 15k in the vehicle already. I JUST found out as we raised the vehicle to put aftermarket diff covers and when we open the rear m220 we saw an open diff. We turn the wheels and sure as day both wheels spun in opposite directions!!
If anyone knows how to start a claum like please help!!
Jeep Wrangler JL Correction FCA did their job! Screenshot_20230629_181654_Driv
Jeep Wrangler JL Correction FCA did their job! IMG_0420
Stetson
Salt Lake City
2019 JL Sahara, 2023 392 Rubicon, 2020 GMC 3500 Denali
Project Manager
Although your order sheet specifies the anti-spin…did the window sticker say the same? If it is not on the window sticker then you may be out of luck.
They might just say ‘you are right, you didn’t get one and you didn’t pay for one’.
I am not an expert on all the models, but I thought all Willy’s had the anti-spin as basic equipment.
Stetson
Sahara4xeland
Andy
Miami
JL Willys Sport XR.
Stetson
Yes all willys should have them and XR non rubicon has them as per the package. Window sticker says it as well... it just sucks!!!
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Pretty sure one wheel spinning opposite of the other is completely normal for the type of LSD used in the JL.
Stetson
Salt Lake City
Project Manager
If that is the case…probably need to double check and make sure you don’t have one before you open a case…
you might be good to go after all
Sahara4xeland
Andy
Miami
JL Willys Sport XR.
I
I always thought that was they to test if you had one in or not as per everything I read... anyway you can point me to this info?
jaymz
Jay
Inland Empire
Sahara4xeland
Andy
Miami
JL Willys Sport XR.
jaymz
Jay
Inland Empire
LOL.. exactly what i tested... Post 4 talks about if wheel spin in different directions NO LSD.. and that is my case.... pluse we opened it and it is in fact an open diff.. LSD are closed and contain clutches and such...
Was the trans in park or neutral?
All LSD’s aren’t necessarily closed.
The Wrangler’s clutches are between the carrier and the spider gears. Almost impossible, if not impossible to see them with everything installed.
Here’s an exploded view:
https://www.quadratec.com/jeep-repl...r-jl/dana-44-standard-rear-differential-parts
Sahara4xeland
Andy
Miami
JL Willys Sport XR.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
I
The clutch pack (if you have it) does not apply until there is some resistance to the oppsite wheel.
DonH63
Don
Monument, CO
21 GC Trailhawk, 23 JLU 392 XR
Retired EE; musician (trumpet)
My very vague recollection from years ago was open or LSD would spin tires opposite directions when both were off the ground. One tire on the ground would show if it was open (one tire spins) or LSD (would bind). A locker would spin both tires the same direction when they were in the air. Not really sure, just a memory of a memory when I added a LSD and tested it with one wheel in the air (on a jack stand) and one on the ground.
