Cooling problems with 3.6
Petey
Pete
Miami
2020 jl sport manual
Not that it really matters with Jeep dealers as they all seem to follow their own rules, but my radiator was leaking at 38 months with 31,000 miles and my local dealer would not cover the repair under the powertrain warranty.
yup that is jeep
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Yes... needs a new thermiator .. "maximum thermal power of the radiator should be greater than thermal power of the engine".- I wish I could joke about this but were in 2000s and very few american manufacturers seemed to figure this out. Our systems are taxed with oil and exhaust cooling . It just seems to me that they field tested vehicles in the arctic during the winter.
I don't think you are understanding thermal power. The total Tdelta across the HX is the indication of its Q. The highest temps on Earth should not result in overheating of the engine under any normal driving conditions. Some other system failure must occur first.
Petey
Pete
Miami
In that case combustion pressures /temps are at play u say
Petey
Pete
Miami
Be more specific? I don’t know what you mean.
coolant might be exposed at some point .. to combustion temps (gasket mating surface) ... but he should also check the pump for proper flow which nobody mentioned this would stagnate the cooling process ..can cause overheating .. Ive seen pumps eaten from the inside.
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
Welp, I got some pics of radiator - top few inches are caked in mud - washing may have helped clean the lower parts out - last pic is top - other pic is middle - then also a pic from the bottom up
Jeep Wrangler JL Cooling problems with 3.6 1329D69B-5893-4517-B130-87B55AFD7E60
Jeep Wrangler JL Cooling problems with 3.6 971C2E38-6A0C-41DC-888B-88DEDF2E1283
Jeep Wrangler JL Cooling problems with 3.6 494F02A7-DBC2-414B-B806-319455D41F0F
Jeep Wrangler JL Cooling problems with 3.6 7030E07A-4453-480C-A512-E99A0CDCCB89
Petey
Pete
Miami
yep get er clean ur ac is going work better too!! if ocd compels u get those fins straight .Also get some of ac coil cleaner in there
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
I'm thinking ill just hose it off as much as I can, and if that doesn't solve the issue I'll replace the flush the coolant & replace the radiator
The big black one in front is the AC correct? and the little black one in front & above is the power steering correct?
Could just the top few inches of it being full of mud cause much higher temps???
Petey
Pete
Miami
the bottom photos look pretty darn nasty .. give it the hose if this helps now u know ...the front is the ac condenser ..it doesnt matter if u dont know which is which ...all should be clean ..make clean everything make clean... its at least part of ur problem to say the least.. u should notice a difference but how much.. only u will find out.
DaltonGang
Doesn't Play Well With Others
Well, this may be a good sign. Stress the system out, and let us know if cleaning the radiator. Worked.
mwilk012
Service
sure, on a 20 year old Buick maybe, but this is a 4-5 year old Jeep. It’s not the water pump.
I doubt it’s the head gasket because he isn’t consuming coolant.
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
Washed out radiator, looked like quite a bit of dirt came out, going to test it this weekend to see if it still overheats
DanW
Thats what they sold me but what amount is it now?
Is it 70k? Or maybe 60k? I'm not sure. I'll have to check.
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
The warranty stuff is very weird - my warranty expired ages ago, but the California emissions warranty is covering my ECU replacement(not sure if this is unique to CA registered vehicles?), and chrysler is covering my steering gear replacement - all despite it only having a powertrain warranty (which only covers lubricated parts)
Petey
Pete
Miami
you should feel at least some difference.
