Coolant filling question
WI_Sarge
WI
2024 wrangler sport S
Hello, first turbo. There are 2 coolant reservoirs. Do I fill these independently? They are not tied together at some point? My engine reservoir is full, but the back black one is lower. Thanks in advance
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Correct, same coolant type, but separate reservoirs.
The cap has a little cut in it that you stick a flat head through to turn. Do it cold.
WI_Sarge
WI
Perfect thanks
Old Dogger
Bill
Cave Creek Arizona
Use only MOPAR OAT 50/50 Mix antifreeze.
WI_Sarge
WI
Yeah im gonna stop at the dealer and get the mopar brand. Thanks.
THAW
Foster
23 JL4DrRubicon
Point of clarification: the black reservoir in the back near the firewall is for the engine. The smaller transparent one near the grille is for the turbo.
roaniecowpony
Retired Engineer
You could just add a bit of water as well. For a little top off, water is fine. Probably best to use a distilled water to prevent adding minerals that lead to corrosion. But there's a lot of corrosion inhibiter in the coolant already.
If you were changing the coolant, of course you'd need the OEM recommended coolant, but just topping off, not so much.
Also, any of the big name coolants of the right type are fine.
WI_Sarge
WI
Point of clarification: the black reservoir in the back of the bay is for the engine. The smaller transparent one toward the grille is for the turbo.
good to know, thanks!
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Really... I always assumed it was the other way around because of their locations. Whaddya know.
Anyway, they're both necessary and both need to be checked and topped off with the same fluid so I guess it doesn't really matter until you go beyond basic maintenance.
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
What if you use an aftermarket coolant that will work. For example, my Jeep puked out most of the coolant back in 2021 because of those loose bolts. I went and just used the Zerex brand and it's still in there. I wonder what happens to the engine and or coolant system is not using the Mopar brand? I hear people say you need to use it but never a reason as to what happens if you use another that meets the specs.
Old Dogger
Bill
Cave Creek Arizona
If one flushes out the complete engine cooling system, then it is a non-issue. But you don't want to mix, OAT and HOAT, or these auto parts store, our antifreeze works in all cooling systems. Because mixing them may cause a lack of corrosion protection, plus sometimes a gel will form, plugin up the cooling system. It is best to use what the factory recommends. MOPAR OAT 50/50 Mix antifreeze.
NWJeepr
Twin Peaks
2025 Wrangler 2-door
As long as the aftermarket coolant meets spec (check your owner's manual), it's fine. You can mix different colors and brands of coolant as long as they are the same type.
Our 2.0's specify OAT (not HOAT) coolant.
TrentYoung
Trent
Phoenix
2024 Jeep Wrangler Rubicon X 4Xe
Never ever add water.... only in case of extreme dire emergency.
